MHB Tilting a circle or ring over backwards creates an ellipse....
Tilting a hoop or ring backwards transforms its appearance from a circle to an ellipse, prompting the need to calculate the area of the resulting ellipses based on the tilt angle. The horizontal axis of the ellipse remains equal to the original circle's radius, while the vertical axis decreases as the tilt increases. The vertical axis can be calculated using the formula: (original height) x sin(tilt angle), with a clarification to use the absolute value to prevent negative results in certain quadrants. This approach allows for accurate area calculations of the ellipses formed at various tilt angles. Understanding these geometric transformations is essential for precise mathematical modeling.
Pogster
What I would like to be able to calculate is the following:
Suppose a hoop or ring is held up perpendicular to the ground and you stood in front of it, it would look perfectly circular and knowing the radius you could calculate the area of this circle. Now if this hoop was tilted over backwards it would look elliptical to you the observer. I need to be able to calculate the area of the resulting ellipses for any angle of tilt of my hoop.
Would the following be correct: The horizontal axis length of all the ellipses that result from tilting my hoop over are going to be the same as that of the original circle but the vertical axis is going to get progressively less. Can I therefore ignore the horizontal axis and treat the vertical axis as a pole falling over backwards and as it falls it's height decreases by: (original height) x sin (tilt angle). Which means for different tilt angles I can calculate the minor axis and with this value and the constant major axis length calculate the area of the resulting ellipses?
Mathematics news on Phys.org
Hello and welcome to MHB, Pogster! (Wave)
I agree with your reasoning, except I think we need to use:
(original height)·|sin (tilt angle)|
to avoid negative values when the tilt angle might be in the 3rd or 4th quadrants. :)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
