Time and gravity on the quantum level?
In summary, according to the conversation, gravity has an effect on time at the quantum level, but not always. The effects are less as the mass of an object decreases. When time is slowed down, it is only detectable when comparing clocks at different elevations.
jarroe
40
Time and gravity on the quantum level??
Gravity has been proven to slow time, and gravity has less an effect the smaller the object, and little to no effect at the quantum scale. So can we calculate the lessening effect of gravity with decreasing mass of an object? Then can we stretch out time in relation to that correlation to quantify time on the quantum level?
Not all effects of gravity are less with smaller objects. Remember the story of Galileo dropping two balls of different size off the Tower of Pisa? The same with how time is affected by gravity. A big clock and a small clock will tick the same under the same influence of gravity. So the answers to your two questions are "no". Are you thinking maybe something along the lines of how you would weigh less on the moon than you do on their earth?
No, I just thought since time is relative and affected by very large objects in space that warp space-time, I thought if we could extraoplate it mathmatically down to the quantum level guess I was just seeing if time on the quantum scale could be quantified as moving different from time at the normal large scales?
But even when time is slowed down, such as it is to a very small extent on the surface of the Earth at different elevations, all objects experience the same slow down and so it is not detectable. It's only when we compare how fast a clock is ticking at one elevation to an identical clock at a different elevation that we can detect the difference.
FAQ: Time and gravity on the quantum level?
What is the relationship between time and gravity on the quantum level?
The relationship between time and gravity on the quantum level is not well understood. According to the theory of general relativity, gravity affects the passage of time by warping the fabric of space-time. However, on the quantum level, time is treated as a discrete variable and does not follow the same rules as in classical physics.
Can time be affected by gravity on the quantum level?
There is evidence that time can be affected by gravity on the quantum level. This is seen in experiments such as the famous double-slit experiment, where particles seem to behave differently depending on whether they are being observed or not. This suggests that gravity may play a role in the behavior of time on the quantum level.
How does quantum entanglement affect the concept of time?
Quantum entanglement, where two particles become connected in such a way that the state of one affects the state of the other, can have implications for the concept of time. In some theories, it is suggested that entangled particles may be able to communicate faster than the speed of light, which challenges our understanding of causality and the flow of time.
Is there a connection between gravity and the arrow of time?
The arrow of time refers to the concept that time only moves in one direction, from past to present to future. There is ongoing research into whether gravity plays a role in this directional flow of time. Some theories suggest that the expansion of the universe and the force of gravity may be linked to the arrow of time.
Can we use quantum mechanics to understand the nature of time and gravity?
Quantum mechanics, the branch of physics that studies the behavior of matter and energy on the smallest scales, has been successful in explaining many phenomena in the natural world. However, it has not yet been able to fully explain the relationship between time and gravity on the quantum level. Further research and experimentation is needed to better understand this complex relationship.
