What Determines the Time Constant for an Inductor in Different Switch Positions?
In summary, the correct time constant for the circuit is T = 2L/R because when the switch is closed, the inductor "sees" both resistors and the total resistance is R + R = 2R. This is obtained by using Ohm's law and solving for the currents. However, when the switch is open, the inductor only "sees" one resistor and the time constant is L/R. To calculate the time constant for the switch-closed case, one must determine the equivalent resistance of the network by removing the inductor and suppressing any sources.
TrolliOlli
The original question:
Notice that they have marked that the correct time constant is T = 2L/R
Why is this the correct answer and not L/R? I thought the inductor will only take into consideration one Resistor as in both circuits (switch closed vs open), current will only flow through one resistor at a time.
EDIT: Moderator's note -- I have moved this thread from Advanced Physics to Intro Physics -- Redbelly98
Hi...!
Have you tried using Ohm's law, and solving for the currents?
It seems that one can obtain the right answer by doing that; Recall that the voltage that is exerted on both the Inductor and the second resistor is not V but V-I*R, and thus you should obtain the proper image, I'd think.
Daniel
For Question 21 they really should have specified whether the switch is open or closed. The circuit will have a different time constant for each position.
When the switch is open the inductor "sees" only one resistor, the rightmost one. So the time constant is L/R. But when the switch is closed it "sees" both resistors. Until the circuit reaches steady-state after a long time, currents will be flowing in both resistors (Eventually the inductor looks like a short circuit current flows only through the lower-left R).
In order to calculate the time constant for the switch-closed case you will have to determine what total resistance the inductor "sees". To do that, remove the inductor from the circuit and suppress any sources (in this case you short the battery). Determine the equivalent resistance of the resulting network looking into the inductor's connection points.
https://www.physicsforums.com/attachment.php?attachmentid=41329&stc=1&d=1322484717
FAQ: What Determines the Time Constant for an Inductor in Different Switch Positions?
What is the definition of time constant for an inductor?
The time constant for an inductor is the amount of time it takes for the current in an inductor to reach 63.2% of its maximum value when a constant voltage is applied.
How is the time constant for an inductor calculated?
The time constant for an inductor is calculated by dividing the inductance of the inductor (in henries) by the resistance of the circuit (in ohms).
Why is the time constant important for inductors?
The time constant is important because it helps determine how quickly an inductor can respond to changes in voltage. It also helps in designing and analyzing circuits with inductive components.
What factors can affect the time constant for an inductor?
The time constant for an inductor can be affected by the inductance, resistance, and capacitance in the circuit, as well as the type of material used in the inductor and the frequency of the current.
How does the time constant for an inductor differ from that of a capacitor?
The time constant for an inductor and a capacitor are calculated differently and have different units. The time constant for an inductor is measured in seconds, while the time constant for a capacitor is measured in units of time multiplied by capacitance (e.g. seconds times farads).
