Time dependence in quantum theory
In summary, perturbation theory in quantum mechanics and QFT can be used to calculate time-dependent quantities through the use of time-independent methods. This is evident in the calculation of various important results such as scattering cross-sections, decay rates, and energies of bound states. Examples of this can be seen in the use of the Dyson series in Feynman diagrams and Fermi's golden rule. While a strict time-dependent approach may be needed in certain cases, the time-independent approach is often sufficient in obtaining transition probabilities. This is demonstrated in scattering theory, where the S-matrix elements can be derived using time-independent perturbation methods, as explained in S. Weinberg's "The Quantum Theory of Fields, Vol. 1".
TrickyDicky
3,507
27
I'm trying to elucidate certain concepts about time dependence and perturbation theory in quantum mechanics and QFT.
I get the impression that most of the important results that in principle can be considered to have a time dependence can actually be calculated in terms of time-independent perturbation methods. I'm thinking for example about the case of scattering both in QM and QFT particle physics, where most of the important calculations like scattering cross-sections, decay rates, energies of bound states, etc can be made by matching the asymptotic states of the time-independent Hamiltonian in the context of the S-matrix.
Or the use of the Dyson series in the context of the Feynman diagrams in QED perturbative renormalization.
And Fermi's golden rule which is a time-dependent perturbation derivation that can also be used in the context of time-independent problems.
It seems the strict time-dependent perturbation is only needed to obtain the quantum transition probabilities under a external perturbation.
Is the above impression correct, or is it wrong and if so can someone give examples of applications or physical problems where the time-dependent perturbation is used in the everyday practice either within the formal obtention of transition probabilities or beyond?
Yes, it's correct. By definition, scattering theory is about transition probabilities between asymptotically free in and out states. Although the time-dependent approach with wave packets is the most intuitive and physically correct way to derive the definition of the corresponding S-matrix elements, you can also entirely work in terms of time-independent perturbation theory. See, e.g., S. Weinberg, The Quantum Theory of Fields, Vol. 1, where this is very well explained in the context of relativistic QFT.
Related to Time dependence in quantum theory
1. What is time dependence in quantum theory?
Time dependence in quantum theory refers to the concept that the state of a quantum system can change over time. This change can be described by the time-dependent Schrodinger equation, which takes into account the time evolution of the system's wave function.
2. How does time dependence affect quantum systems?
Time dependence is a fundamental aspect of quantum systems as it allows for the prediction and understanding of how a system will evolve over time. It also plays a crucial role in phenomena such as quantum tunneling and the behavior of entangled particles.
3. Can time dependence be observed in experiments?
While the effects of time dependence can be observed in experiments, it is not directly observable itself. This is because time is treated as a parameter in the mathematical equations of quantum theory, rather than a physical observable like position or momentum.
4. How does time dependence differ from time independence in quantum theory?
Time independence in quantum theory refers to systems that do not change over time, and can be described by the time-independent Schrodinger equation. In contrast, time dependence takes into account the changing state of a system over time and is necessary for understanding the behavior of dynamic quantum systems.
5. What are some applications of time dependence in quantum theory?
Time dependence is essential in many applications of quantum theory, such as quantum computing, quantum cryptography, and quantum simulations. It also plays a crucial role in understanding the behavior of complex systems, such as molecules and atoms, at the quantum level.
  • Quantum Physics
  • Quantum Physics
