I Time-dependence in the Hamiltonian
  • I
  • Thread starter Thread starter Llukis
    Hamiltonian
Llukis
TL;DR Summary
How to tackle time-dependent Hamiltonians
Last week I was discussing with some colleagues how to handle time-dependent Hamiltonians. Concerning this, I would like to ask two questions. Here I go.
First question
As far as I know, for a time-dependent Hamiltonian ##H(t)## I can find the instantaneous eigenstates from the following equation
$$H(t) |n(t)\rangle = \epsilon (t) |n(t)\rangle \: ,$$
where ##\epsilon(t)## is the eigenvalue at each instant of time. Thus, for each time ##t##, the states ##|n(t)\rangle## form a basis and, therefore, I can write a general state of the system as
$$|\psi(t)\rangle = \sum_n c_n (t) |n(t)\rangle \: .$$
Is this statement correct? This means that the basis and the corresponding coefficients vary with time continuously.
If this is correct, can I go a step further and choose, for convenience, my basis at ##t=0##? In other words,
$$|\psi(t)\rangle = \sum_n a_n (t) |n(t=0)\rangle \: ,$$
where the basis is static and the coefficients are different from the previous ones.
Second question
Imagine that I can write my Hamiltonian as the sum of two terms (both depending on time)
$$H(t) = H_0(t) + H_1(t) \: ,$$
and that I am interested in working in the interaction picture where ##|\psi^\prime (t) \rangle = U^\dagger_0(t) |\psi(t)\rangle##, with
$$U_0(t) = \mathcal{T} e^{-\frac{i}{\hbar}\int H_0(t^\prime)dt^\prime} \: .$$
Is this possible? Does the interaction picture remain valid when ##H_0## is a function of time? Perhaps it is not convenient to work in the interaction picture in this case, but I want to know if it is still well defined.
Thanks in advance for reading my post!
First question: You can of course choose this basis, but it won't help you much to solve your problem.
Second question: That's the correct procedure to switch from the Schrödinger to an interaction picture, where the eigenvectors of observable time-evolve with ##\hat{H}_0##, i.e., the unitary operator ##\hat{U}_0^{\dagger}##, while the state vectors time-evolve with ##\hat{H}_1## with the corresponding unitary operator
$$\hat{U}_1(t)=\mathcal{T} \exp \left [-\frac{\mathrm{i}}{\hbar} \int_0^t \mathrm{d} t' \hat{H}_0(t') \right].$$
Thanks for taking your time to answer my questions!
So, I could write the state ##|\psi (t) \rangle## in the changing basis ##|n(t)\rangle## or choose a static basis at any given time, for instance at ##t=0##. I wanted to be sure about that, thank you.
By the way, how would you face the problem of a time-dependent Hamiltonian? I would like to have some insights.
Regarding your answer to the second question, I know the procedure is correct, but I would like to know if even for a time-dependent ##H_0(t)## the interaction picture is still valid; I mean if it works in the same way that it does for a time-independent ##H_0##.
Thank you so much.
The only time dependence in the basis vectors will arise as a phase so it is simplest to consider the basis the same as in the initial time and then just multiply by the time dependent phase.
Thank you so much.
Formally it works the same as with a time-independent ##\hat{H}_0##, but it will be quite more complicated.
Likes Llukis
For a Hamiltonian with some general explicit time-dependence it's unfortunately not a simple phase factor. That makes such problems so complicated.
Likes nucl34rgg
Sorry for my delay, I was a little bit busy so far.
Thanks for your answers. Let me add another question, just to be sure. Once I have found the instantaneous eigenstates of a ##H(t)##
$$H(t) |n(t)\rangle = \epsilon_n (t) |n(t)\rangle \: , $$
can I write the spectral decomposition of the Hamiltonian? This is to say
$$H(t) = \sum_n \epsilon_n (t) |n(t)\rangle \langle n(t) | \: ,$$
at each instant ##t##.
Another point I would like to clear up is if applying the time-evolution operator on a instantaneou eigenstate gives
$$\mathcal{U}(t) |n(t)\rangle = \exp \bigg( -\frac{i}{\hbar} \int_0^t \epsilon_n (t^\prime) dt^\prime \bigg) |n(t)\rangle \: . $$
Thank you all!
