Time Dependent Wave Function for Particle in Infinite Square Well
In summary: This definitely helps me understand where I was going wrong. In summary, the problem is solved by using the equation sin(theta) = (1/2i) * (e^(i*theta) - e^(-i*theta)) to remove the imaginary term from the time-dependent wavefunction and probability density calculation. It is important to have a real probability density for physical meaning.
LunaFly
35
A particle is in a bound state of the infinite square well. It is in a state represented by the following wavefunction, written here at t=0:
ψ(x)= -√(2/3)√(2/L) * sin (3πx/L) + i*√(1/3)√(2/L) * sin (2πx/L)
(a)Write the full time-dependent wavefunction for this state, and calculate the time-dependent probability density.
(b)Use a computer program to plot the probability density at a series of time steps to show how the probability density evolves with time.
**Note: I used "h" to represent h-bar below.
Schrodinger equation: -h2/(2m) * ∂ψ(x,t)/∂x + V(x,t) * ψ(x,t) = ih * ∂ψ(x,t)/∂t
From deriving the time-independent wave function of particle in infinite square well: ψ(x,t)= ψ(x)*ø(t),
with ø(t)=e-i*E*t/h
Energy of particle in nth state En = n22*h2/(2*m*L2)
I know that the ψ(x) given is a linear combination of energy eigenfunctions, the first being from the n=3 state and the second being from the n=2 state of the particle in an infinite square well.
My first instinct was to multiply each individual eigenfunction by the ø(t) that corresponds to said state. I ended up with a wavefunction of:
ψ(x,t)= -√(2/3)√(2/L) * sin (3πx/L) * e-i*E3*t/h + i*√(1/3)√(2/L) * sin (2πx/L) * e-i*E2*t/h,
with E3= energy of particle in n=3 state, and E2= energy of particle in n=2 state.
This all seemed fine and dandy. It solved the time-dependent Schrodinger equation, so I was pleased.
Where things got weird was when I calculated the probability density, ψ*ψ. I ended up with the equation:
ψ*ψ= (2/L) * (2/3 * sin2(3πx/L) + 1/3 * sin2(2πx/L) + i*√(2)/3 * sin (2πx/L) * sin (3πx/L) * (ei*(E2-E3)*t/h - ei*(E3-E2)*t/h))
This is consistent with the problem statement in that ψ(x, 0) = ψ(x); however I feel like the imaginary term in there is wrong. How can the probablility have an imaginary component? I have tried using Euler's formula to transform the eikt term but still end up with an imaginary term.
This also leads to the problem of plotting this probability density function. Is it possible to make a plot with an imaginary term? I am using Mathematica but haven't found much information on the subject.
Any insight to where I went wrong or how to continue and deal with the imaginary term would be most appreciated.
I think you want this:
[itex]\sin{\theta}=\frac{1}{2i} [e^{i\theta}-e^{-i\theta}][/itex]
See how the energies are mismatched in the second exponential term? If you pull out the negative you will get it in this form. If you use the above formula you will get a real probability (see the [itex]i[/itex] on the bottom?).
Remember also that the modulus squared of the wave function must be real to be physically meaningful.
Excellent! Thank you for the reply, electricspit. This is exactly what I need to cancel out all of the "i"'s in the expression.
Also thanks for the clarification about the probability density.
FAQ: Time Dependent Wave Function for Particle in Infinite Square Well
1. What is the Time Dependent Wave Function for Particle in Infinite Square Well?
The Time Dependent Wave Function for Particle in Infinite Square Well is a mathematical expression that describes the behavior of a particle confined to an infinite potential well under the influence of time. It is a solution to the Schrödinger equation, which is a fundamental equation in quantum mechanics.
2. How is the Time Dependent Wave Function for Particle in Infinite Square Well derived?
The Time Dependent Wave Function for Particle in Infinite Square Well is derived by solving the Schrödinger equation for the infinite square well potential. This involves applying boundary conditions, such as the wave function must be continuous and have a finite value at the boundaries of the well.
3. What are the properties of the Time Dependent Wave Function for Particle in Infinite Square Well?
The Time Dependent Wave Function for Particle in Infinite Square Well has several properties, including: it is a complex-valued function, it is normalized (the total probability of finding the particle in the well is equal to 1), and it oscillates with time.
4. How does the Time Dependent Wave Function for Particle in Infinite Square Well change with time?
The Time Dependent Wave Function for Particle in Infinite Square Well changes with time due to the oscillatory behavior of the wave function. As time increases, the wave function will oscillate between positive and negative values, representing the changing probability of finding the particle in different locations within the well.
5. What is the significance of the Time Dependent Wave Function for Particle in Infinite Square Well?
The Time Dependent Wave Function for Particle in Infinite Square Well is a fundamental concept in quantum mechanics and is used to understand the behavior of particles in confined systems. It also serves as a basis for more complex systems and can be applied to other problems in quantum mechanics, such as the behavior of electrons in atoms.
