Time Derivative of Rank 2 Tensor Determinant
In summary: The Attempt at a SolutionMy approach is the following: we know that ## det(a) = \frac{1}{6} \epsilon_{ijk} \epsilon_{lmn} A_{il}A_{jm}A_{kn} ##Applying the time derivative to this:## \frac{d}{dt} det(A) = \frac{1}{6} \epsilon_{ijk} \epsilon_{lmn} (A_{il}'A_{jm}A_{kn}+ A_{il}A_{jm}'A_{kn}+ A_{il}A_{j
Marcus95
50
Show that for a second order cartesian tensor A, assumed invertible and dependent on t, the following holds:
## \frac{d}{dt} det(A) = det(a) Tr(A^{-1}\frac{dA}{dt}) ##
## \frac{d}{dt} det(A) = \frac{1}{6} \epsilon_{ijk} \epsilon_{lmn} (A_{il}'A_{jm}A_{kn}+ A_{il}A_{jm}'A_{kn}+ A_{il}A_{jm}A_{kn}') ##
## = det(A) (\frac{1}{A_{il}} A_{il}' +\frac{1}{A_{jm}} A_{jm}' + \frac{1}{A_{kn}} A_{kn}') ##
This is starting to look somewhat like the expression we look for, but from here on I am stuck. Any ideas on how to continue? Many Thanks!
I suggest that you do not use index expressions. They will just cluster up, you gain no real insight here, and you are making your proof specific to the 3x3 case.
Instead, I suggest that you use the relation ##\operatorname{det}(e^B) = e^{\operatorname{tr}(B)}##.
Likes StoneTemplePython
I think trying to work it out in terms of the definition of determinant is the hard way. Instead, I think that the quickest way to the answer---assuming that you've already learned these things--uses the following facts:
  • If ##A## is invertible, then there is an invertible matrix ##Q## and a diagonal matrix ##\Lambda## such that ##A = Q \Lambda Q^{-1}##
  • The trace of a matrix is the sum of its diagonal entries.
  • The determinant of a diagonal matrix is the product of its diagonal entries.
  • Both trace and determinant are invariant under cyclic permutations of matrices: ##det(XYZ) = det(YZX)## and ##tr(XYZ) = tr(YZX)##
I think that those facts are enough to get you to the answer.
I presume that scalars are in ##\mathbb C## for this post
This is news to me. In general the rank of ##\mathbf A##'s collection of eigenvectors determines diagonalizability. The rank of ##\mathbf A## itself really has no bearing on diagonalizability (ignoring nits like how to think about rank zero matrices).
Note that ##\mathbf A## can always be triangularized i.e. ##\mathbf A = \mathbf{STS}^{-1}## where the triangularization is either Jordan Form or Schur Form, depending on needs and tastes.
For this problem, this holds I think, but the statement strikes me as dangerous. For convenience I'll define ##\mathbf B := \mathbf{YZ}##
Technically trace has a provable cyclic property over square matrices, but determinants don't -- they have a multiplicative property. In general these operations are valid when ##\mathbf B## is ##n ## x ##m## and ##\mathbf X## is ##m## x ##n##.
i.e. ##trace\big(\mathbf {BX}\big) = trace\big(\mathbf {XB}\big)##, but we can only be sure that ##det\big(\mathbf {BX}\big) = det\big(\mathbf {XB}\big)## if ##m = n## (or if we know there is a rank deficiency for both, then both have determinants of zero). Another way to think about it is, if ##m = n## we can write ##det\big(\mathbf {XB}\big) = det\big(\mathbf X\big) det\big(\mathbf B\big) = det\big(\mathbf {BX}\big)## i.e. we get commutativity--which gives you a cyclic property for free.
A better statement in my view is that ##\big(\mathbf {XB}\big)## and ##\big(\mathbf {BX}\big)## have the same non-zero eigenvalues-- or equivalently, the same characteristic polynomials, after factoring out zero roots. Trace gives the sum of eigenvalues -- equivalently, the sum of non-zero eigenvalues. Determinant is product of eigenvalues -- and this in general is impacted by the presence of extra zero roots (which must occur if ##m \neq n##).
My mistake. I leapt to the assumption that the matrix ##A## was square and diagonalizable.
Since the OP mentions "Cartesian tensor", I think it is safe to assume that we are talking about a square matrix.
Likes Marcus95
Yes, I think it is safe to assume that, even if previous posts are interesting.
I have now seemingly solved the problem with help of the exponential form:
## det(A) = e^{lnA} = e^{Tr(lnA)} ##
applying differentiation with product rule and assuming it can be taken inside the trace:
## \frac{d(det(A)}{dt} = e^{Tr(lnA)} \frac{d}{dt} Tr(lnA) = det(A) Tr(\frac{1}{A} \frac{dA}{dt}) ##
However, this creates some questions for me. Are the standard differentiation rules really applicable to matrices like this? Can the inverse really be taken to be 1/A for the matrix? Isn't "matrix division" sort of undefined or does the negative exponent have some more general meaning here?
Moreover, whereas I have seen the exponential form used in certain "extra questions", it is not strictly a part of my maths course. Do you have any suggestions on how to solve the problem using the index expression? It might not be very general indeed, but previous parts of this question used it so I think I might be expected to do it here too.
Many thanks to you all this far! :)
Related to Time Derivative of Rank 2 Tensor Determinant
1. What is the definition of the time derivative of a rank 2 tensor determinant?
The time derivative of a rank 2 tensor determinant is a mathematical operation that calculates the rate of change of the determinant of a rank 2 tensor with respect to time. It is commonly denoted as ∂det(T)/∂t.
2. How is the time derivative of a rank 2 tensor determinant calculated?
The time derivative of a rank 2 tensor determinant is calculated by taking the determinant of the time derivative of the tensor. This can be done by differentiating each component of the tensor with respect to time and then taking the determinant of the resulting matrix.
3. What is the significance of the time derivative of a rank 2 tensor determinant?
The time derivative of a rank 2 tensor determinant is significant in the field of physics and engineering as it allows for the calculation of important quantities such as velocity, acceleration, and stress in dynamic systems.
4. How does the time derivative of a rank 2 tensor determinant relate to other mathematical concepts?
The time derivative of a rank 2 tensor determinant is closely related to the concept of differentiation in calculus. It also has connections to other mathematical concepts such as vector calculus and linear algebra.
5. Can the time derivative of a rank 2 tensor determinant be applied in real-world scenarios?
Yes, the time derivative of a rank 2 tensor determinant can be applied in real-world scenarios, particularly in the fields of physics and engineering. It is used in the analysis and modeling of dynamic systems such as fluid flow, structural mechanics, and electromagnetism.
