Dale
Mentor
- 36,454
- 15,186
Reference frames still exist in any theory. There are two common meanings for reference frames:externo said:But in LET what is the rocket's frame? if the front and the back are not synchronized, how can we speak of a reference frame?
First, reference frames are coordinate systems used to assign position and time numbers to events. That is part of the mathematical analysis. LET and BU use the exact same math for the coordinate transforms.
Second, reference frames are a system of physical clocks and rulers used to assign position and time numbers to events. That is part of the experimental setup. This is an experimental fact independent of any theory.
In both cases reference frames are every bit a part of LET as BU.
Again, the fact that you think they are not part of LET shows a misunderstanding of LET. Note, this comment is not said as someone promoting a stance on the BU vs LET debate (they are both valid interpretations), but as a professional physics educator. You misunderstand the math of how LET works. It does not work the way you claim. You have a vague grasp of the philosophy, but not the concrete math. So please take some instruction on the topic.
externo said:Question: Where does the velocities and accelerations difference between the rear and the front come from?
This is a fallacious argument. Just because two points on a rigid object have different velocities and accelerations does not imply that it is due to length contraction. In Newtonian physics two objects at rest in a rotating reference frame will have different proper accelerations and in an inertial frame will have different velocities. That doesn’t imply length contraction caused it. Relativistic acceleration is a hyperbolic rotation, so it shares this kinematical fact with Newtonian rotational motion.externo said:Here is an argument: The contraction is the cause that the rear and the front do not have the same proper acceleration, and the proper acceleration is felt in the reference frame of the rocket.
To show that length contraction is the cause will require an actual derivation, your simple assertions and rhetorical questions are insufficient.
