Time Dilation & Bosons: Decay Rate Changes?
In summary, the conversation discussed the possibility of bosons capable of pair production having their decay rate changed if they pass through a material. While there is no evidence to support this idea, it was noted that interactions between particles and a medium could potentially affect the decay channels available. The concept of time dilation, particularly in relation to light slowing down when passing through a medium, was also brought up. It was suggested that this phenomenon can be explained through classical or quantum mechanics, and that the interaction between light and the medium can also change its properties.
Andrew Wright
120
Hi,
It is easy to find discussions about time dilation and muon Half-Life. Is it meaningful to discuss whether bosons capable of pair production can have their decay rate changed if they pass through material?
Andrew Wright said:
it meaningful
I didn't understand what you said, so probably not.
Likes vanhees71
Andrew Wright said:
time dilation
What does passing through a material have to do with time dilation?
Likes vanhees71
One could imagine some physical interaction between particle and medium which affects the particle in some way. However there is zero evidence or reason to think that such a hypothetical interaction might change the decay rate…. and even if such a thing were possible it would be unrelated to relativistic time dilation. An easy way to see this is to use a frame in which the particle is at rest and the medium is moving - there is no time dilation in that frame.
Likes vanhees71
I was thinking of light slowing down when it passes through a medium. People have told me that this is due to interactions that happen to bend and slow the light. It feels odd that a bunch of particle interactions happen to make light refract like a water wave. It always felt like it should not just pop out of particle interactions because it looks like wave behaviour.
If you're talking classically, light is slowed and refracted because it's an EM wave and it interacts with the EM fields of the medium. If you're talking quantum mechanically I think that basically the same thing is true; it's a mistake to think of a photon as a pointlike particle because it has no position operator - it's always spread out and wavelike. But you should probably wait for an answer from someone who's a bit better at QFT than me!
In terms of entering the medium changing decay rates, I'd think that the interactions with the matter change the decay channels available and their relative cross-sections anyway, and it would be hard to separate that from any supposed relativistic effects.
Likes vanhees71
Indeed, you can just use relativistic QFT as well in many-body theory. You get the "properties of an in-medium photon" through calculating the self-energy (or propagator) in the medium. For a very good introduction to this physics, see
J. I. Kapusta and C. Gale, Finite-Temperature Field Theory;
Principles and Applications, Cambridge University Press, 2
edn. (2006).
or
M. LeBellac, Thermal Field Theory, Cambridge University
Press, Cambridge, New York, Melbourne (1996).
FAQ: Time Dilation & Bosons: Decay Rate Changes?
What is time dilation and how does it relate to bosons?
Time dilation is a phenomenon in which time appears to pass at a different rate for objects that are moving at different speeds. This is a key concept in Einstein's theory of relativity. Bosons, which are particles that carry forces between other particles, can experience time dilation due to their high speeds and interactions with other particles.
How does time dilation affect the decay rate of bosons?
According to Einstein's theory of relativity, time dilation causes time to pass more slowly for objects that are moving at high speeds. This means that for bosons moving at high speeds, time will appear to pass more slowly and their decay rate will also appear to slow down. This is known as the "time dilation effect" on bosons.
Can time dilation be observed in experiments with bosons?
Yes, time dilation has been observed in experiments with high-speed particles such as bosons. For example, in the Large Hadron Collider, scientists have observed the decay rate of bosons to be slower than expected due to the effects of time dilation.
How does the speed of a boson affect its decay rate?
The speed of a boson can have a significant impact on its decay rate due to the effects of time dilation. As a boson approaches the speed of light, its decay rate will appear to slow down significantly. This is because time appears to pass more slowly for objects moving at high speeds, according to Einstein's theory of relativity.
Are there any other factors that can affect the decay rate of bosons?
Yes, there are other factors that can affect the decay rate of bosons, such as the strength of the force that they carry and the environment in which they are interacting with other particles. However, time dilation is a key factor that can significantly alter the observed decay rate of bosons.
