Time Dilation: Clock A & B Confusion
In summary, there are two clocks, A and B, moving with a relative speed of ##v##. The time intervals for two events are ##t_0## for clock A and ##t## for clock B. According to the Lorentz transforms, ##t=\gamma t_0## and ##t_0=\gamma t##, showing that time runs slower for clock B compared to clock A. However, this only applies when the two events occur at the same spatial location. The general expression for time dilation is the Lorentz transforms, and it is recommended to use them instead of the time dilation formula. Additionally, events at different locations that are simultaneous in one frame are not simultaneous in a frame moving at a constant
Haorong Wu
413
89
TL;DR Summary
time dilation
Suppose there are two clocks. Clock B is moving with a speed of ##v## relative to clock A. Then clock A is moving with a speed of ##-v## relative to clock B.
Let ##t_0## be the time interval for two events in the framework of clock A, while ##t## be the time interval for the same two events in the framwork of clock B.
Then ##t=\gamma t_0##. Since ##\gamma## is greater than one, so for clock B time runs slower than for clock A.
But, also, ##t_0=\gamma t##, then time in clock A runs slower than in clock B.
This seems wrong. But where?
Thanks!
This is not true in general. It is only true in the special case that the two events occur at the same location in frame A.
Likes Haorong Wu and PeroK
They can't possibly be the same two events except in the trivial case where ##v=0##.
Likes Haorong Wu
As others have pointed out, ##t=\gamma t_0## is a special case that only applies when the events happen at the same spatial location. That will only apply to at most one frame (unless ##v=0##, as @Mister T notes).
The general expression is the Lorentz transforms:$$\begin{eqnarray*}
t'&=&\gamma\left(t-\frac v{c^2}x\right)\\
x'&=&\gamma\left(x-vt\right)
\end{eqnarray*}$$and their inverse:$$\begin{eqnarray*} t&=&\gamma\left(t'+\frac v{c^2}x'\right)\\ x&=&\gamma\left(x'+vt'\right) \end{eqnarray*}$$Note that you need to specify the time and position of each event and transform each one separately to get its transformed time and position. Then you can work out the time difference in either frame. (A useful trick is to declare that the origin is where and when one of the events is - ##(x,t)=(0,0)## transforms to ##(0,0)##.)
We generally recommend that you forget you ever heard of the time dilation formula and always use the Lorentz transforms until you are comfortable enough with them that you can see instantly whether you are allowed to use the time dilation formula in a given situation or not.
Likes etotheipi, Dale and Haorong Wu
Thanks, guys. I got it now. I forgot that the clock A remain still relative to the two events. Thanks again!
Likes Dale
Events are points in spacetime. To say that a clock is at rest relative to two events does not make sense. Instead, what you might mean is what @Dale said: that the two events occur at the same place in the rest frame of clock A.
Likes vanhees71
Related to Time Dilation: Clock A & B Confusion
What is time dilation?
Time dilation is a phenomenon in which time appears to pass at different rates for objects that are moving at different speeds or in different gravitational fields. This is one of the key principles of Einstein's theory of relativity.
What is the clock A and B confusion in time dilation?
The clock A and B confusion refers to the concept that two clocks, A and B, can experience different rates of time due to their relative speeds or positions in a gravitational field. This can lead to a discrepancy in the time shown on each clock.
How does time dilation affect space travel?
Time dilation plays a significant role in space travel as it affects the perception of time for astronauts traveling at high speeds or in strong gravitational fields. This can result in astronauts experiencing time at a slower or faster rate compared to people on Earth.
What evidence supports the theory of time dilation?
There is a significant amount of evidence that supports the theory of time dilation, including experiments with atomic clocks, observations of the behavior of particles in particle accelerators, and the accuracy of GPS systems. Additionally, the predictions made by the theory of relativity have been consistently confirmed through various experiments and observations.
Can time dilation be observed in everyday life?
While time dilation is most noticeable at extremely high speeds or in strong gravitational fields, it can still be observed in everyday life on a very small scale. For example, GPS systems must account for the effects of time dilation in order to accurately calculate location and time. Additionally, the difference in time experienced by astronauts in space compared to those on Earth is a real-life example of time dilation.
