gnieddu
- 24
- 1
- Homework Statement
- Two clocks are placed on the earth's surface. One is kept still while the other is thrown upwards with an initial small velocity ##v_0##. How will the time measurements differ between the two clocks according to SR only and to GR only?
- Relevant Equations
- Equation describing the motion of a body in earth's gravitational field following Newton's laws: ##z=v_0t-\frac{1}{2}gt^2##
Proper time under Minkowski metric (with (+, -, -, -) signature): ##c^2d{\tau}^2=-ds^2=c^2dt^2-dz^2##
The non-moving clock will see the other one move upwards and land as predicted by Newton's laws, so using the equation ##z=v_0t-\frac{1}{2}gt^2##, and assuming the moving clock starts at ##t=0##, it will land at ##t=\frac{2v_0}{g}##.
Now, using SR only, and the Minkowski metric (with signature (-,+,+,+)) the time ##\tau## measured by the moving clock is obtained by using the equation:
$$c^2dτ^2=−ds^2=c^2dt^2−dz^2$$
where dz can be obtained from the equation of motion by differentiating:
$$dz=d[v_0t−\frac {1} {2} gt^2]=(v_0−gt)dt$$
In the end, we need to evaluate:
$$τ=\frac {1} {c} \int_0^{\frac {2v_0}{g}}[c^2−(v_0−gt)^2]dt $$
If we consider GR only, the solution follows the same line, but the metric would be the one for the weak field approximation:
$$ds^2=−(1+\frac{2gh}{c^2})c^2dt^2+dz^2$$
with the added complexity of expressing h as ##v_0t-\frac{1}{2}gt^2##.
In both cases, the integrals are not nice, but can possibly be simplified by using the approximation ##\sqrt{1+x}=1+\frac{x}{2}##. All of this, of course, if my plan of action makes sense and I'm not missing anything.
Thanks in advance
Gianni
Thanks in advance
Gianni
