Time Dilation happens on moving frame - but which one?
In summary, the concept of time dilation in special relativity is relative and not absolute. Both frames moving relative to each other observe time dilation in the other frame. The twin paradox, which involves one twin traveling at high speeds and experiencing time dilation, can be resolved by using the Lorentz Transform or studying the behavior of clocks in the two frames. However, some may find this explanation unsatisfactory and there are ongoing discussions and debates about the twin paradox in the scientific community. Ultimately, the assertion that the twin in the spaceship is younger is based on experiments with subatomic particles, but has not yet been directly proven with spaceships.
controlfreak
58
As per theory of special relativity the time in moving frame R' is supposed to run slowly compared to the stationary frame R. But isn't the stationary frame R moving wrt frame R' in the opposite direction. For an observer in stationary frame R', R would be moving with the same velocity wrt to it and wouldn't he think time will dilate in R which is the moving frame according to that observer in frame R'? So if time dilates in both, wouldn't both measure the same time? This has been confusing me for a while though I understand the equations which Lorentz framed to satisfy the absolute velocity of flight.
controlfreak said:
wouldnt both measure the same time?
Yes, each frame measures the same clock rate for the clock that moves in that frame.
If two frames are moving wrt each other, then they both observe time dilation in the other frame - in the sense that both observe clocks and any physical processes (hence time itself) running slower in the other frame. Time dilation, like motion itself, is relative, and not "absolute".
Also, "moving frame" is relative not absolute; a frame can only move relative to another and is not absolutely "moving".
Understanding how and why this symmetry of time dilation can be resolved is a central aspect of understanding SR. It can be done by the using the Lorentz Transform or by directly studying the behaviour of clocks in the two frames relative to each other.
I realize I was talking about the twin paradox. The explanation as given in this link is that (http://en.wikipedia.org/wiki/Twin_paradox) asymmetry is introduced when the twin returns back to compare the times as to return back one needs a change in velocity, an acceleration.
This provides an analysis of Twin Paradox resolutions - http://www.iisc.ernet.in/~currsci/dec252005/2009.pdf - This whole thing doesn't seem to be fully and satisfactorily resolved. First of all why do we make the assertions that the spaceship twin is younger? Has that been proved by experiments which indirectly attest to that? or does theory predict that?
Use the search function then. It has been explained to death here.
Likes controlfreak and PeroK
That's not correct; it is.
We haven't done it with spaceships, obviously, but we've done it with subatomic particles many times. As A.T. says, use the PF search function; you will find many, many threads where the twin paradox has been discussed to death. Another good discussion is the Usenet Physics FAQ article on the twin paradox (which you will also find linked to in many of those other threads):
http://math.ucr.edu/home/baez/physics/Relativity/SR/TwinParadox/twin_paradox.html
Pay particular attention to the "spacetime diagram analysis"; that is the most general method of analysis and generalizes to all possible scenarios in curved spacetime as well. It also, as the FAQ article says, allows you to put all the other methods of analysis in their proper perspective.
If you have further questions after reading through what's already been written and discussed, please start a new thread with a specific question. This thread is closed.
Likes controlfreak
Related to Time Dilation happens on moving frame - but which one?
1. What is time dilation?
Time dilation is a phenomenon in which time appears to pass at a different rate for objects that are moving at different speeds. This is a consequence of Einstein's theory of relativity, which states that the laws of physics are the same for all observers in uniform motion.
2. How does time dilation happen on a moving frame?
Time dilation occurs because the speed of light is constant in all frames of reference. When an object is moving at high speeds, the distance that it travels in a given amount of time is greater than if it were stationary. This causes time to appear to slow down for the moving object.
3. Which frame experiences time dilation?
Both frames experience time dilation, but the effect is more noticeable for the moving frame. This is because the stationary frame is considered the "rest" frame and time appears to pass normally in this frame.
4. Is time dilation a real phenomenon?
Yes, time dilation has been confirmed through various experiments and observations. For example, atomic clocks on airplanes have been found to run slower than those on the ground due to the high speeds they are traveling at.
5. What are the practical implications of time dilation?
Time dilation has significant implications for space travel and satellite communication. It must be taken into account when making precise measurements and calculations, as even small differences in time can have a significant impact.
