Time Dilation in accelerated frame
In summary, the post discusses finding a condition for synchronizing two clocks when one is accelerated. It mentions the time dilation formula for an inertial frame and questions if it can be applied to time varying speeds. However, it is later discovered that the Lorentz transformation is only valid for constant speeds.
VVS
91
Hi, I have an exercise where we are supposed to find a condition for which two clocks are synchronise if one clock is accelerated.
The time dilation in an inertial frame moving with velocity [itex]v[/itex] is well known. [itex]t'=\frac{t}{1-\frac{v^2}{c^2}}[/itex]
My question is whether this formula can be generalized for time varying speeds such that the time passed in the accelerated frame is given by: [itex]t'=\int_0^t \frac{1}{1-\frac{v(\tau)^2}{c^2}}d\tau[/itex]
Thanks for the post! Sorry you aren't generating responses at the moment. Do you have any further information, come to any new conclusions or is it possible to reword the post?
No problem. I found out that the Lorentz transformation is only valid for constant speeds. So what I thought is wrong. thanks anyway
Related to Time Dilation in accelerated frame
What is time dilation in an accelerated frame?
Time dilation in an accelerated frame refers to the phenomenon where time passes at a slower rate for an observer in an accelerated frame of reference compared to a stationary observer. This is a consequence of Einstein's theory of relativity.
What causes time dilation in an accelerated frame?
Time dilation in an accelerated frame is caused by the increase in speed and energy of the observer in the frame. As the observer's velocity increases, time slows down for them relative to a stationary observer.
How is time dilation in an accelerated frame measured?
Time dilation in an accelerated frame can be measured using precise clocks and measuring the difference in time between a stationary observer and an observer in an accelerated frame. This measurement is known as the time dilation factor.
Does time dilation in an accelerated frame only occur in extreme speeds?
No, time dilation in an accelerated frame can occur at any speed, although it becomes more significant at higher speeds. Even the Earth's rotation causes a small amount of time dilation.
What are some real-world applications of time dilation in an accelerated frame?
Time dilation in an accelerated frame has practical applications in fields such as space travel, where astronauts experience time dilation due to their high speeds. It also plays a role in GPS technology, where the satellite clocks need to be adjusted for the effects of time dilation in an accelerated frame.
