Time Dilation in the same frame of referance?
In summary: I don't really know, trying to make a point?It's difficult to say without knowing more about what you're trying to say. In general, clocks at different locations experience different amounts of time dilation because they are moving.
Klairence Leitch
A rocket ship is accelerating through space. Clocks P and Q are at opposite ends of the ship. An astronaut inside the rocket ship is beside clock P and can also observe clock Q.
What does the astronaut observe about the passage of time for these clocks? Justify your answer.
Note: There is a diagram given in the question and clock P is at the top ('north') of the rocket ship and Q is at the other end. The rocket is accelerating in towards 'north'.
I don't think there would be a difference in time at the clocks are accelerating with the same magnitude/ direction, so although clock Q is accelerating towards the astronaut at P, the astronaut and clock P are being accelerated away from clock Q.
Would they both occupy the same frame of reference? I'm not very confident in my answer and I feel as though I might be missing something? This is an advanced higher question (equivalent to English A level) and it's worth 2 marks.
No, you're not missing anything. If you take a frame of reference in which a part of the ship is stationary, then everything in the ship is in stationary in that frame of reference including both clocks and the astronaut. Well, things like the HANDS of the clock and stuff like that are moving but you get the picture.
You are incorrect however in saying that either of the clocks is accelerating relative to the astronaut since they are all stationary in the same frame of reference.
Likes Klairence Leitch
A frame of reference is not something that can be occupied.
It would be proper to say that there is a[n accelerating] frame of reference in which the astronaut and both ends of the spacecraft are continuously at rest.
Better yet, why not just do what I suggested and consider a frame of reference in which the ship is stationary?
Likes Klairence Leitch and jbriggs444
Have you been studying the equivalence principle and/or the relativistic Doppler effect?
Thank you for helping, I understand where I went wrong with my logic.
Thank you for your help, I'll keep this in mind for next time.
I have recently been taught the equivalence principle and the relativistic Doppler effect, though my knowledge of the latter is limited.
A mass at P has more potential energy than one at Q.
Think of the work required to move a mass from Q to P.
The situation is much the same as a tower on Earth experiencing 1G acceleration.
How would a clock at the top of the tower run, compared to one at the bottom?
You are bringing in gravitational time dilation which, I believe, is not relevant to the heart of the OPs question who appears to be asking about time dilation due to motion.
@Klairence Leitch, jump in if I am wrong.
I don't think the question is asking about gravitational time dilation - it does not mention anything about a gravitating mass that would cause there to be a gravitational potential, so I'm assuming that it is just time dilation.
Though it is accelerating through space, so I don't know if I am to assume that the acceleration is due to the rocket being in a gravitational field (linking into the equivalence principle)? I'm not very sure. I'm sorry if I'm not being very clear.
The OP's question appears to be about clocks with different potential energy.
There is no mention of motion in the original post.
Assuming the acceleration is 1G, the same result could be obtained (apart from tidal effects etc) if the rocket was still sitting on the launchpad.
I see no harm in hinting that in the OP 'A rocket ship is accelerating through space.' could be replaced with 'A rocket ship is accelerating.'
I cross posted.
The equivalence principle means you can't tell without looking outside the spaceship, so thinking about such experiments on Earth would give you the answer.
i.e.
'Though it is accelerating through space, so I don't know if I am to assume that the acceleration is due to the rocket being in a gravitational field (linking into the equivalence principle).'
- you can assume either and still get the right answer.
I cross posted.
i.e.
So, looking back at the question, Clock Q would be observed to show time moving faster as it has a weaker gravitational potential (because it is further from the source of gravitation). Is that right? Or am I missing something?
Yes. My original answer was wrong overall because I was distracted by your discussion of RELATIVE acceleration so was only considering motion, not the equivalency principle, which others have correctly brought into the analysis.
Okay, thank you very much for your help. Despite not being part of the homework question, I feel a lot more confident about frames of reference from your post.
Thank you for all of your help!
I think you understand but got mixed up.
P has greater potential energy and runs faster. (You have to add energy to a mass to move it from Q 'up' to P.
Don't say 'gravitational potential' unless you know it is as you lose generality - the whole point of equivalence.
Do look up atomic clocks in a tower and try to see why the tower's equivalent to a spacecraft accelerating in a negligible gravitational field.
x-posted again... goodnight!
@Klairence Leitch it seems like I am destined to do nothing but contribute to your confusion in this thread. Listen to @Carrock instead
I assumed you got it right this time and didn't go back to see which one was higher in the equivalent gravitational well. Carrock has been paying attention. It's good that one of us has. :smile:
Likes Klairence Leitch and Carrock
Carrock said:
[Clock] P has greater potential energy and runs faster.
The astronaut would observe Clock P to be ticking at the correct rate (neither fast nor slow) because the astronaut is standing next to it.
Which is correct but irrelevant as to which clock is running fast relative to the other.
As long as both Clocks P and Q are ticking at the correct rate (neither fast nor slow), and if the observation interval lasts long enough, all observers will agree that a different amount of time has passed at Point P than has passed at Point Q.
The answer (according to the answer scheme) was:
Time on clock P will appear to move faster
or
Time on clock Q will appear to move slower (1 mark for either)
Time passes more slowly at the rear of an accelerating object
or
Time between pulses from clock Q would take longer to reach the astronaut (1 mark for either)
FAQ: Time Dilation in the same frame of referance?
What is time dilation in the same frame of reference?
Time dilation in the same frame of reference is a phenomenon in which time appears to pass at different rates for two observers who are in the same frame of reference but are moving at different speeds.
How does time dilation occur in the same frame of reference?
Time dilation occurs due to the effects of special relativity, which states that the passage of time is relative to the observer's frame of reference and is affected by their relative speed and gravitational fields.
What is the equation for time dilation in the same frame of reference?
The equation for time dilation in the same frame of reference is t' = t√(1 - v²/c²), where t' is the time measured by the moving observer, t is the time measured by the stationary observer, v is the relative velocity between the two observers, and c is the speed of light.
How does time dilation in the same frame of reference affect space travel?
Time dilation in the same frame of reference affects space travel by causing time to pass slower for objects in motion compared to those at rest. This means that astronauts traveling at high speeds will experience time differently than people on Earth, resulting in a difference in age when they return.
Is time dilation in the same frame of reference a proven phenomenon?
Yes, time dilation in the same frame of reference has been proven through numerous experiments and observations, such as the famous Hafele-Keating experiment in 1971. It is a fundamental aspect of special relativity and has been confirmed by many scientific studies.
