Time emergent from entanglement
In summary, the article and the thread discussing it state that time emerges from quantum entanglement. If you assign a quantum state to the universe as a whole, it does not change with respect to the time parameter that gets imposed by non-relativistic QM.
TheQuestionGuy14
159
[Moderator's note: Spin off from a previous thread since this topic belongs in the QM forum.]
PeterDonis said:
Which page? Give a link.
Again: we cannot discuss out of context quotes from an unknown source. Either give a specific link to the actual discussion you're asking about or this thread will be closed.
https://physics.stackexchange.com/questions/423835/is-time-emergent-from-quantum-entanglement
It is the first answer.
PeterDonis said:
Coordinate time is a coordinate label that you put on events in spacetime (more precisely, one of four coordinate labels that you put on each event, assuming you are using appropriate coordinates).
Proper time is the time elapsed on a clock between two events on the clock's worldline.
Then what is the person who replied talking about? The experiment wants to show that time emerges from quantum entanglement, he states only measured time is, and parametric time isn't, what is he talking about?
Ibix said:
Proper time is the "distance" along a timelike worldline. If you arrange a set of parallel inertial (i.e. straight) timelike worldlines, this is one direction of a grid. If you agree a zero on all of the lines (preferably so that the zeros form a line orthogonal to each timelike line) then you have coordinate time.
It's exactly like the distinction between the length of any old line and the length along a set of parallel straight lines (which you'd call a y-coordinate) in Euclidean geometry.
So what is this guy I quoted in OP explaining? Is he correct or incorrect?
My reading is that he's showing that clock measurements emerge from quite simple quantum systems. Einstein said time is what clocks measure - the paper is a (partial?) explanation of why that is so.
I may not be reading it right. I've only read the abstract and the stack exchange post.
Likes bhobba
PeterDonis said:
Not coordinate time or proper time. So if you were hoping to get information about what those are, that StackExchange thread is not the way to do it--nor is the paper linked to there.
In quantum mechanics (more precisely, non-relativistic QM), the time ##t## is a parameter; the state of the overall quantum system is a function of this parameter, but the parameter is just imposed by the theory, it has nothing to do with anything that's measured or anything physical.
"Measured time" in the paper is the change in the correlations between the subsystems of the overall quantum system as measurements are made on them, interpreted as evidence of "time flowing", as part of a proposal made by the authors of the paper on how we, as individual subsystems in the universe, could perceive time to be flowing (or, to put it another way, things to be changing), when, if you try to apply non-relativistic QM to the whole universe and assign the whole universe a quantum state, the Hamiltonian you get out of it says the state of the whole universe never changes at all as a function of the parameter ##t##.
As above, none of this has anything to do with either coordinate time or proper time as those concepts are used in relativity. A discussion of the paper and the StackExchange thread really belongs in the QM forum, not here, if that's what you want to ask about. But such a discussion has nothing to do with coordinate time or proper time.
OK, so, speaking of the experiment, is it correct? Does time emerge from entanglement? And if so, how could the universe be static to an external observer if planets, stars, people are clearly moving?
Clock measurements can emerge from entanglement. Clock measurements are not time.
(See disclaimer in my previous post)
But the experiment states that from an external observer, the universe would be static, as the observer is not entangled with the photons, only when an internal observer entangles with the photon pair, time can be measured. Thus time itself emerges from entanglement.
There is no "external observer" for the universe as a whole. That is one key reason why I am skeptical of the argument given in the paper.
Likes TheQuestionGuy14
That's not actually what the math says. The math just says that if you assign a quantum state to the universe as a whole, it does not change with respect to the time parameter that gets imposed by non-relativistic QM.
As I said in my previous post, the idea of an "external observer" for the universe as a whole doesn't make sense, so any such interpretation of what the math says does not seem correct or useful to me.
Also, as I've noted, the math in question is non-relativistic QM, and a non-relativistic model does not seem correct or useful for the universe as a whole. At the very least, a valid model for something like this would need to be formulated in quantum field theory; but we don't have a good quantum field theory of gravity, so we don't have a good way of formulating models like this for the universe as a whole.
Likes bhobba, Ibix and TheQuestionGuy14
Related to Time emergent from entanglement
1. What is "time emergent from entanglement"?
"Time emergent from entanglement" is a theory proposed in the field of quantum physics that suggests that time itself may be a consequence of the entanglement of particles. This means that the flow of time may not be a fundamental aspect of the universe, but rather a result of the way particles interact and become entangled with one another.
2. How does entanglement relate to the concept of time?
Entanglement is a phenomenon where two or more particles become connected in such a way that the state of one particle affects the state of the other, no matter how far apart they are. In the theory of time emergent from entanglement, it is proposed that the entanglement of particles gives rise to the perception of time passing, as the entangled particles continuously change and interact with each other.
3. What evidence supports the theory of time emergent from entanglement?
While the theory is still being explored and is not yet widely accepted, there have been several studies that have shown a connection between entanglement and the passage of time. For example, some experiments have shown that the entanglement between particles can affect the rate at which time passes for those particles. Additionally, the mathematical framework of quantum mechanics, which describes the behavior of entangled particles, also allows for the concept of time emergent from entanglement.
4. What are the implications of time emergent from entanglement?
If the theory of time emergent from entanglement is true, it would fundamentally change our understanding of time and the nature of the universe. It may also have implications for other areas of science, such as the study of black holes and the concept of a "beginning" or "end" of the universe.
5. Is time emergent from entanglement a widely accepted theory?
No, the theory is still being researched and debated among scientists. While there is evidence to support the idea, it is not yet widely accepted in the scientific community. More research and experimentation is needed to fully understand the relationship between entanglement and time.
