Time for a bomb to hit the ground
In summary, the conversation discusses dropping a bomb from an aeroplane to start a controlled burn. The question is how long it will take for the bomb to hit the ground. The solution involves using the concepts of horizontal and vertical components of velocity, with the suggestion to use kinematic equations. The recommended formula is to use s[y] = 490m and the acceleration along the x-axis = 0 and acceleration along the y-axis = gravity. The answer is estimated to be around 10 seconds rather than the initial estimate of 6.53 seconds.
tzek
Bush fir patrols sometimes drop small bomb to start a controlled burn off from aeroplanes. Peter was flying his over a forest at constant horizontal speed of 75m/s and at contsant altitude of 490m when he dropped the bomb.
A) how long does it take for the bomb to hit the ground?
we have a displacement (490m) , an acceleration (gravity, 9.8 m/s/s) and a velocity (75m/s), so v = u + at could be transposed to give time, however I am hopeless at this. please advise..
after some fiddling around with other formulae such as t = s/v = 6.53 s.. which according to the answers section is wrong.. they say 10s.. is this right? please advise me on this ASAP please..
Welcome To PF.
When the bomb is dropped from the aeroplane it has some horizontal velocity which is equal to the velocity of the aeroplane i.e. 75 m/s.
Use concepts of horizontal and vertical components of velocity.Use accln along x axis=0 and accln along y-axis = g.Use s[y]: 490 m.
Now use simple kinematic equations.
suggestion= the simple basic formulae are very important but in these kinda questions they will not be aplicable becoz as there are horizontal and vertical components of velocityand accln involved.
I would approach this problem by first identifying the relevant equations and variables. In this case, we have the displacement (490m), initial velocity (75m/s), and acceleration due to gravity (9.8m/s^2). We can use the equation s = ut + 1/2at^2 to solve for the time it takes for the bomb to hit the ground.
Plugging in the values, we get 490m = (75m/s)(t) + 1/2(9.8m/s^2)(t^2). Rearranging the equation, we get 0 = 4.9t^2 + 75t - 490. Using the quadratic formula, we get two possible values for t: t = 10s or t = -9.9s. Since time cannot be negative, we can conclude that it takes 10 seconds for the bomb to hit the ground.
It is important to note that this calculation assumes that the bomb is dropped from rest (u = 0). If the plane was already moving at a constant horizontal speed of 75m/s before the bomb was dropped, then the time it takes for the bomb to hit the ground would be slightly longer. This is because the horizontal velocity of the plane would contribute to the horizontal displacement of the bomb. However, since the problem does not specify the initial speed of the plane, we can assume that it was dropped from rest and use the value of 10 seconds.
FAQ: Time for a bomb to hit the ground
What factors determine the time it takes for a bomb to hit the ground?
The time it takes for a bomb to hit the ground depends on several factors such as the height from which it is dropped, the initial velocity, and the force of gravity. Additionally, air resistance and wind can also affect the time it takes for a bomb to reach the ground.
Does the shape of the bomb affect its fall time?
Yes, the shape of a bomb can affect its fall time. A more aerodynamic shape will experience less air resistance and therefore fall faster than a less streamlined shape.
How does the force of gravity impact the time for a bomb to hit the ground?
The force of gravity is the main factor that determines the time it takes for a bomb to hit the ground. Gravity pulls the bomb towards the center of the Earth, causing it to accelerate towards the ground. The greater the force of gravity, the faster the bomb will fall.
Can the time for a bomb to hit the ground be calculated?
Yes, using the equation t = √(2h/g), where t is the time, h is the initial height, and g is the acceleration due to gravity (9.8 m/s^2), the time for a bomb to hit the ground can be calculated. However, this equation assumes no air resistance and a constant gravitational force.
How does altitude affect the time it takes for a bomb to hit the ground?
Altitude can affect the time it takes for a bomb to hit the ground in two ways. First, the greater the initial height from which the bomb is dropped, the longer it will take to reach the ground. Second, at higher altitudes, the force of gravity is slightly weaker, so the bomb may fall slightly slower than at lower altitudes.
