Time for rocket shot upward to reach the ground
A model rocket releases its first stage at 100.0 m altitude and 40.0 m/s upward. To calculate the time until it hits the ground, the equation Y = Yo + VyoT + 1/2GT^2 is used. The initial attempt resulted in a negative square root, indicating an error in the values used for gravity. The correct values are Y=0, Yo=100 m, Vyo=40.0 m/s, and G=-9.8 m/s^2. Adjusting the acceleration due to gravity resolves the issue.
helpmedude
A model rocket releases its first stage when it is 100.0 m above the ground and moving upward at 40.0 m/s. Ignoring air resistance, find:
the time it takes the first stage to hit the ground
Y=Yo+VyoT+1/2GT^2
Quadratic
I got to [-(40)+-Squareroot(1600-1960)]/9.8
the problem is that the square root of a negative number is an imaginary number so I am just wondering what I am missing here?
Hi helpmedude,
Y=Yo+VyoT+1/2GT^2
Quadratic
I don't believe that is correct. What numbers did you use for Y, Y0, Vy0, and G?
my bad I forgot to make acceleration due to gravity negative that's why it didnt work geez. thanks anyways. Y=0 Yo=100m Vyo=40.0m/s G=-9.8m/s^2 I used 9.8m/s^2
9K
12K
25K
