B Time for which a vertical projectile stays motionless in midair
When a projectile is thrown vertically, it momentarily stops at its highest point, but this stop occurs instantaneously, lasting zero seconds. The velocity at this peak is zero only at that exact moment, as it transitions from positive to negative velocity due to gravity. The acceleration is a constant negative value, leading to a linear decrease in velocity until it reaches the ground. Understanding this concept requires the application of Differential Calculus, which allows for the calculation of instantaneous values as intervals approach zero. Thus, while the projectile appears to stop, it does so without any measurable duration.
Curiosity_0
We know that if a projectile is thrown vertically, there will be a brief time when it momentarily stops. Can we calculate this brief moment?
That moment will be an instant, not a period of time.
It's zero seconds. It's the same for any other velocity on its trajectory.
As others have said, the velocity is zero only instantaneously. These plots of the vertical motion of a projectile should help. See how the acceleration due to gravity is a constant negative value (-g)?, and how the velocity decreases linearly from the initial ##v_0## down through zero to end up being ##-v_0## when the projectile impacts the ground?
https://cnx.org/resources/d7690f6d7871dafd158630fc8ea5b60846d9c9bf/PG12C1_007.png
Likes Spinnor, Tom.G, topsquark and 1 other person
It will stop at a particular clock-reading, but that clock-reading lasts for zero time.
As soon as the projectile reaches its highest point it starts to descend, it spends zero time at the highest point
Likes hutchphd, topsquark and Ibix
We 'think' we know that. Reasonable enough because things happen pretty slowly at the high point it would really boil down to how quickly and accurately we could actually measure that velocity. Zero velocity is actually no more special than +1m/s or -1.05m/s. This was a problem for the old Physicists until the concepts involved in Differential Calculus were introduced. The theory is that you consider a smaller and smaller interval between two (imagined) measurements the limit as the interval approaches zero is the 'true' value of the velocity.
Likes hutchphd and topsquark
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
