Time-independent perturbation theory
So, in summary, the reason why we can write the perturbed energies and wavefunctions in that way is because it is an assumption based on the smallness of the perturbation.
ehrenfest
2,020
In each of my QM books, they always say something like "we can write the perturbed energies and wavefunctions as"
[tex]E_n = E_n^{(0)} + \lambda E_n^{(1)} + \lambda^2 E_n^{(2)} + \cdots [/tex]
[tex] |n\rangle = |n^{(0)}\rangle + \lambda |n^{(1)}\rangle + \lambda^2 |n^{(2)}\rangle + \cdots [/tex]
without any justification. This is really not obvious to me and although it seems reasonable, it do not see why the perturbed energies and wavefunctions might not be something completely different like
[tex]E_n = E_n^{(0)} + \lambda E_n^{(1)} + \lambda^2 \log \left(E_n^{(2)}\right)^{-1}\sin E_n^{(2)} + \cdots [/tex]
Expanding the energies and wave functions as a function of the perturbation parameter is an iterative manner which is well behaved. The function you wrote for the energy has poles and in multivalued.
You are right that it's an assumption that is being made. The assumption is that the perturbation Hamiltonian is a small perturbation, which means that as lambda goes to zero, the energies and wavefunctions smoothly approach the unperturbed results. This assumption does fail in some cases (for example, trying to treat the Couloumb potential in Hydrogen as a perturbation would fail completely because the energy expansion would diverge in lambda which would signal the fact that the Coulomb potential has to be included to all orders so it cannot really be treated as a perturbation)
FAQ: Time-independent perturbation theory
What is time-independent perturbation theory?
Time-independent perturbation theory is a mathematical method used in quantum mechanics to analyze the effects of a small perturbation on a known system. It allows for the calculation of the energy levels and wavefunctions of the perturbed system without having to solve the entire problem from scratch.
How does time-independent perturbation theory work?
In time-independent perturbation theory, the Hamiltonian of the perturbed system is expressed as a sum of the unperturbed Hamiltonian and a small perturbation term. This allows for the use of the unperturbed eigenstates to approximate the perturbed eigenstates through a series expansion. The resulting energy corrections can then be calculated and used to improve the accuracy of the eigenstates.
What are the limitations of time-independent perturbation theory?
Time-independent perturbation theory assumes that the perturbation is small enough that the unperturbed eigenstates can still be used as a basis. It also assumes that the perturbation is time-independent and that the system is in a stationary state. These limitations make it unsuitable for systems with large perturbations or time-dependent perturbations.
How is time-independent perturbation theory applied in practice?
In practice, time-independent perturbation theory is used to calculate the energy levels and wavefunctions of atoms, molecules, and other quantum systems. It can also be applied in condensed matter physics to analyze the electronic structure of materials. The results obtained from this theory can be compared to experimental data to validate its accuracy.
Are there any real-world applications of time-independent perturbation theory?
Yes, time-independent perturbation theory has numerous real-world applications, particularly in the fields of quantum chemistry and solid-state physics. It is used to study the effects of external fields on atoms and molecules, as well as to understand the electronic properties of materials. It also plays a crucial role in the development of new technologies, such as quantum computers and advanced materials for electronics and energy storage.
