ralqs
- 99
- 1
Why is it that we assume that the solutions to the time-independent Schrodinger Equation are real? Why can't they be complex?
tom.stoer said:We do not assume that; in general they will be complex.
ralqs said:I'll give you an example from my text:
For the infinite potential well, the TISE is
[tex]\frac{d^2 \psi}{dx^2} = -\frac{2mE}{\hbar^2}\psi = -k^2 \psi[/tex]
The solution to this is given as [itex]A \sin{kx} + B \cos{kx}[/itex], which is real.
Bill_K said:Let me expand on this further. If ψ is a solution of the time-independent Schrodinger equation then so is ψ*, with the same energy E. This is a general consequence of time reversal invariance. And if ψ and ψ* are linearly independent, you may always form real combinations ψ + ψ* and i(ψ - ψ*) and obtain two real solutions.
The Time-independent Schrodinger Equation is a mathematical equation used in quantum mechanics to describe the behavior of a quantum system over time. It is a fundamental equation in the field and is used to determine the energy and wave function of a quantum system.
The Time-independent Schrodinger Equation is important because it allows us to make predictions about the behavior of quantum systems. By solving the equation, we can determine the energy levels and wave functions of a system, which are essential for understanding and manipulating quantum phenomena.
The Time-independent Schrodinger Equation describes the behavior of a quantum system at a single point in time, while the Time-dependent Schrodinger Equation takes into account the change of the system over time. The Time-independent equation is used for stationary states, while the Time-dependent equation is used for non-stationary states.
The Time-independent Schrodinger Equation is derived from the principles of quantum mechanics, specifically the Hamiltonian operator and the wave function of a system. It is a result of the application of the Schrodinger equation to stationary states, which do not change over time.
The Time-independent Schrodinger Equation has many practical applications in the fields of physics and chemistry. It is used to understand and predict the behavior of atoms, molecules, and other quantum systems. It is also used in the development of technologies such as transistors and lasers.
