TIme-independent schrodinger equation
In summary, the time independent Schrodinger equation is represented by E\Psi = Ĥ\Psi. The wave function, denoted by \Psi, is a complex-valued function on space that gives the probability density of finding a particle at a certain point in space when squared. The Hamiltonian operator, Ĥ, is a function that takes \Psi as its input and gives another function as its output. It represents the total energy of the system. The E in the equation represents the specific energy level of the system, chosen from the possible values determined by Ĥ. Another name for \Psi is the quantum state or the quantum mechanical wavefunction.
AbsoluteZer0
125
I've been looking into the time independent schrodinger equation (E[itex]\Psi[/itex] = Ĥ[itex]\Psi[/itex].)
I know that [itex]\Psi[/itex] is the wave function and Ĥ is the hamiltonian operator. I know that Ĥ is the total of all the energies in a system. What exactly is the wave function? Is it a quantum state? And what does the E represent?
Thanks,
The following is for the one-particle case (i.e. a system with one particle).
Mathematically psi is a function on space, expressed as [itex]\psi(x,y,z)[/itex] and it is complex-valued. Mathematically [itex]\psi : \mathbb R^3 \to \mathbb C[/itex]. Its minimal physical meaning is that its modulus squared, mathematically [itex]| \psi |^2[/itex], gives the probability density of finding a particle at a certain point in space.
This is true, in a sense, but I think it's prone to misconception. It is true that knowing [itex]\hat H[/itex] is equivalent to knowing all the energy levels of the system (this is known in mathematics as the spectral theorem for operators) but that is not what [itex]\hat H[/itex] is itself. It is an operator meaning that is a function which takes a function like psi as its argument/its input, and gives another such function as its image/output. A very simple Hamiltonian (that is its name) is [itex]\hat H = -\frac{\partial^2}{\partial x^2}[/itex] (ignoring constants and expressing it in the one-dimensional case). As input it takes a function [itex]\psi[/itex] and as output it gives minus its second derivative with respect to x, this is of course a new function from [itex]\mathbb R^3[/itex] to [itex]\mathbb C[/itex].
E is the specific energy level your system has (in other words you have to choose one; the idea is that you choose the energy level(*) of your system and then calculate what [itex]\psi[/itex] satisfies that equation, and then its modulus squared gives the probability density as discussed above).
(*) Note that you can't choose just any value for E; the possible list is determined by [itex]\hat H[/itex], as you said.
EDIT: yes, another name for [itex]\psi[/itex] is the so-called "quantum state". Also called "the quantummechanical wavefunction".
FAQ: TIme-independent schrodinger equation
What is the time-independent Schrodinger equation?
The time-independent Schrodinger equation is a fundamental equation in quantum mechanics that describes how the energy of a quantum system changes over time. It is used to calculate the energy levels and wave functions of a system in a stationary state.
How is the time-independent Schrodinger equation derived?
The time-independent Schrodinger equation is derived from the time-dependent Schrodinger equation by assuming that the wave function of the system does not vary with time. This allows the time-dependent term to be removed, resulting in a simpler equation that describes the stationary states of the system.
What is the significance of the time-independent Schrodinger equation in quantum mechanics?
The time-independent Schrodinger equation is a cornerstone of quantum mechanics and is used to solve for the energy levels and wave functions of a system. It allows us to make predictions about the behavior and properties of quantum systems, and has been instrumental in our understanding of the microscopic world.
What are the key components of the time-independent Schrodinger equation?
The time-independent Schrodinger equation consists of two main components: the Hamiltonian operator, which represents the total energy of the system, and the wave function, which describes the probability amplitude of the system. It also includes the Planck's constant and the mass of the particle in the system.
What are some applications of the time-independent Schrodinger equation?
The time-independent Schrodinger equation has a wide range of applications in quantum mechanics, such as calculating the energy levels and wave functions of atoms, molecules, and other quantum systems. It is also used in fields such as solid-state physics, quantum chemistry, and nuclear physics to understand the behavior and properties of materials and particles at the atomic and subatomic level.
