Time it takes for the rocket to fall down
In summary, the conversation discusses the calculation of the maximum height and total time for a rocket traveling with acceleration and deceleration. The first part involves finding the maximum height, which is equal to the sum of the distances traveled with acceleration and deceleration. The second part involves finding the total time, which is equal to the sum of the times traveled with acceleration, deceleration, and free fall from the maximum height. The conversation also addresses a discrepancy in the calculation of the free fall time, with one method using the maximum height and the other using the initial height.
Noah159
Rocket is launched straight into the sky. Its engine's provide a constant acceleration of 40m/s^2.
1) What maximum height will it reach, if the engine fuel burns in t1=60 seconds?
2) How fast will the rocket fall into Earth?
V^2-Vo^2=2aS
V(t)=Vo+at
S(t)=Vot+0.5at^2
The first part I can answer. However, the answer to the second one differs from the one in the answer sheet.
1) The rocket first travels gaining speed (a=40m/s^2) and then after the fuel burns loses speed due to g=9.8 m/s^2.
Thus, Hmax= h1 (traveled with a=40) + h2 (traveled with -a=g=9.8)
h1=0.5(at^2)
h2= V1^2/2g (V1= at1), thus h2= (a^2*t1^2)/g
h=h1+h2 = 365.9 km.
Now the hard part - the second.
2) the entire time from start to the rocket reaching Earth once again is t=t1 (traveled with a=40) + t2 (with speed and -a=g) + t3(time it takes to free fall from hmax). t=t1+t2+t3
t1=60 sec (given)
t2= V1/g = at1/g (244.9 sec)
t3= this is the problem. I get different t3 compared to the answer sheet. The answer sheet gives t3= √(2h/g)
However, they take 2h= t1^2*a. (and get t3= t1√(a/g)
How does that make sense? The height used should be Hmax, because it falls from the very top.?
I believe it should be t3= √(2Hmax/g), thus t3= 273.3 sec.?
Help would be appreciated.
It's probably a mistake. If the rocket is falling from ##366\text{km}## in the third stage, you use that value.
Related to Time it takes for the rocket to fall down
1. How is the time it takes for a rocket to fall down calculated?
The time it takes for a rocket to fall down is calculated using the formula t=√(2h/g), where t is the time in seconds, h is the height of the rocket in meters, and g is the acceleration due to gravity, which is approximately 9.8 m/s² on Earth.
2. Does the weight of the rocket affect the time it takes to fall down?
Yes, the weight of the rocket does affect the time it takes to fall down. Heavier rockets will fall faster due to the force of gravity acting on them, while lighter rockets will take longer to fall.
3. How does air resistance affect the time it takes for a rocket to fall down?
Air resistance, also known as drag, can slow down the descent of a rocket by pushing against it as it falls. However, for most rockets, the effects of air resistance are minimal and can be ignored in calculations for the time it takes to fall down.
4. Can the shape of a rocket affect the time it takes to fall down?
Yes, the shape of a rocket can affect the time it takes to fall down. A more aerodynamic shape will experience less air resistance and thus fall faster than a less aerodynamic shape.
5. Does the initial velocity of a rocket affect the time it takes to fall down?
Yes, the initial velocity of a rocket can affect the time it takes to fall down. If a rocket is launched at an angle, it will have a horizontal component of velocity that will affect the time it takes to fall. However, if a rocket is simply dropped from a height, the initial velocity is 0 and will not affect the time it takes to fall.
