Time lag before application of force
In summary, the conversation discusses the timing of the interaction between two charged particles placed at points A and B in space. The expert summarizer explains that the fields created by the charges will meet at the midpoint at a time of d/(2c), resulting in the particles feeling a force due to the interaction of the fields. However, there is also a discussion about the impossibility of simultaneously creating two charges at two different places and the concept of shielding. Ultimately, it is determined that the interaction between the two dipoles would occur at a time of d/c.
americast
27
Hi everyone,
I present a situation here: Say there are two points A and B in space separated by a distance d. I create two charged particles (of any charge) at points A and B at time t=0. After how long will they experience force due to one another?
My answer: We know that electric fields travel at c (the speed of light= 3 x 108 m/s). So, the field from the charge at A will spread out in a spherical way at time t=0. Similarly, the field from B will spread out spherically at the same time t=0. These two field will meet each other at the midpoint on the line joining A and B at a time=d/(2c). We know that interaction of fields leads to force. Field is the cause and force is the effect. Hence, according to me, the answer is t=d/(2c).
Am I correct? If not, where am I going wrong?
Gramercy...
I speculate you are off by a factor of 2 if your thought-experiment detector is actually one of the particles. A particle can't 'know' about a value change at some specific point in a field faster than c, I think.
That is correct. In fact there are a couple of questions here. You will need to specify clearly how you can "create" two charges at two different places, simultaneously.
This is impossible, both for classical EM and also for quantum EM.
I meant to say that I am willing to find after how much time the effect of the field created by both the charges at time t=0 will be felt by the charges, i.e. after how long will the charges feel force acting on them due to the field created by them at time t=0. Assuming that the charges were present from before can be done safely.
This can also be put in a different way. Say, the field created by the charges were being shielded initially and at time t=0, the shield is removed. Now, at what time will force due to the other charge start acting?
And, according to me it should be t=d/(2c). This is because force acts due to interaction of fields (and not due to interaction of field and a charge) and the fields interact for the first time at t=d/(2c).
Gramercy...
Would violate SR.
I think you are confusing some concepts here, the forces acting as a result of an interaction of fields is a QFT thing I think ( admittedly I don't know much about QFT so someone might want to correct me) and the fields they talk about are not the same as the force field you are imagining, for the situation you are describing ( disregarding the impossibility of it) you need the field to get a non zero value at the point where the charge is, so t =d/c
This is essentially possible. Shielding is not magic, it is just opposite charges which cancel out the field of the first charge. So the simplest form of shielding would be a co-located opposite charge which moves away suddenly, forming a dipole at t=0.
With that, your question would be about the timing of the interaction between the two dipoles. If the two dipoles are a distance d apart, then each will feel a force from the other at t=d/c.
My answer would be that it would be t=d/c, it is not the interaction between the fields which moves the particles, it would be the particles interacting with the field, so you'd have to wait until the particle senses a change in the field.
Related to Time lag before application of force
1. What is "time lag before application of force"?
"Time lag before application of force" refers to the delay between the initiation of a force and its effect on an object or system. It is the time it takes for the force to be applied and for the object to respond to that force.
2. Why is the time lag before application of force important to consider?
The time lag before application of force is important because it affects the accuracy and effectiveness of any force applied to an object. If there is a significant time lag, the force may not have the intended effect or may cause unintended consequences.
3. What factors can contribute to a longer time lag before application of force?
There are several factors that can contribute to a longer time lag before application of force, including the type and magnitude of the force, the properties of the object being acted upon, and any external factors such as friction or air resistance.
4. How can the time lag before application of force be reduced?
The time lag before application of force can be reduced by minimizing any external factors that may cause delays, using a more direct and efficient application of force, and choosing the appropriate type and magnitude of force for the specific situation.
5. Are there any real-world applications where the time lag before application of force plays a significant role?
Yes, the time lag before application of force is an important consideration in many real-world applications, such as sports (e.g. hitting a baseball), transportation (e.g. braking a car), and engineering (e.g. designing structures to withstand earthquakes). It is also a crucial factor in the development and use of new technologies, such as robotics and virtual reality.
  • Electromagnetism
