Time period of oscillation of charge in front of infinite charged plane
The discussion focuses on calculating the time period of oscillation for a charged particle near an infinite charged plane. The initial calculation for the time to reach the plane is expressed as t = root(4εmd/σq). It is debated whether the oscillation period is double this time, with a consensus emerging that it should actually be four times t. The final agreement confirms that the correct time period of oscillation is 4t. The conversation highlights the importance of careful analysis in deriving physical equations.
Saptarshi Sarkar
A negetive point charge -q with mass m is held at rest at a distance d from an infinite charged plane with charge density σ and released. Find time period of oscillation (assuming that charge can freely move through plane without disturbing the charge density).
F = -qσ/2ε
a = -σq/2εm
I tried to calculate the time the charged particle will take to reach the plane using the a and using d=1/2at² and found the t to be equal to root(4εmd/σq).
I guess the time period of oscillation will be double of t (by symmetry), i.e. 2root(4εmd/σq). I don't know if this is correct.
I should have looked at your work more closely. You have the picture quite correct.
Only small thing - if t is the time to fall to the plane, is the period really 2t?
Likes Saptarshi Sarkar
Thanks, got it. It should be 4t.
Saptarshi Sarkar said:
Homework Statement:: A negetive point charge -q with mass m is held at rest at a distance d from an infinite charged plane with charge density σ and released. Find time period of oscillation (assuming that charge can freely move through plane without disturbing the charge density).
Homework Equations:: F = -qσ/2ε
OK
a = -σq/2εm
[/QUOTE]
Yes. Good going.
