Time required by a motor to reach the torque
In summary, the cylinder has a weight of 958,000 lbs and the motor has a power of 200 HP and needs to reach 5 RPM in 60 seconds. The required torque to reach this speed is 18,757 lbs-ft. To maintain a constant speed, the torque would need to be zero assuming no friction or energy losses. The calculation of running torque depends on the specifics of the motor design, and can vary for different types of motors such as electric or internal combustion engines.
subbby
I have :
Cylinder : 958,000 lbs
Motor 200 HP
required RPM : 5
time : 60 seconds
Torque: 18,757 lbs-ft
What to find ?
Time required by the motor to reach that torque
Doubt :
  • Is there a chart or a graph that gives this value ?
  • is there any eqaution / formula that helps finding this time ?
  • or is 60 seconds the answer ?
Also, 18,757 is the torque and a 18HP is what is required to reach 5 rpm in 60 seconds. How do you calculate the torque required to keep it running. Isn't, 18,757 the just the start-up torque ?
Assuming no friction or energy losses, how to calculate this running torque?
That all depends on the specifics of the motor design. Electric motors can make peak torque effectively instantly, while internal combustion engines may take some time to develop the peak torque after the throttle input is applied (how much time depends on the details of the motor design).
As for the running torque? If there are no frictional losses, the torque to maintain a given speed is zero. All torque used to maintain a constant speed of rotation is purely to counter the losses in the system.
Related to Time required by a motor to reach the torque
1. What is the definition of "time required by a motor to reach the torque"?
The time required by a motor to reach the torque is the amount of time it takes for the motor to reach its maximum torque output after being turned on.
2. How is the time required by a motor to reach the torque measured?
The time required by a motor to reach the torque can be measured by using a tachometer to monitor the motor's speed and a torque meter to measure the torque output. The time can then be calculated by dividing the torque by the speed at which it was reached.
3. What factors can affect the time required by a motor to reach the torque?
The time required by a motor to reach the torque can be affected by factors such as the motor's size, design, and load capacity. The type of power source and the environment in which the motor is operating can also play a role in the time required to reach the torque.
4. Why is the time required by a motor to reach the torque important?
The time required by a motor to reach the torque is important because it can affect the efficiency and performance of the motor. A longer time to reach the torque may indicate a weaker or less efficient motor, while a shorter time may indicate a more powerful and efficient motor.
5. How can the time required by a motor to reach the torque be reduced?
The time required by a motor to reach the torque can be reduced by using a more powerful motor with a higher torque output, reducing the load on the motor, or improving the motor's design and efficiency. Regular maintenance and proper lubrication can also help to reduce the time required to reach the torque.
10K
  • Mechanical Engineering
  • Electrical Engineering
