Time required for disk to reach angular speed?
In summary, a uniform disk of mass 3 kg and radius 0.22 meters is mounted on a motor that exerts a constant torque of 1 N*m to accelerate the disk from rest. The angular acceleration is 13.77 rad/s^2 and the time required for the disk to reach an angular speed of 800 rpm is 6.08 seconds. It is important to properly track and use units when solving problems involving torque and angular acceleration.
Rijad Hadzic
321
A uniform disk of mass M = 3 kg and radius r = .22 meters is mounted on a motor through its center. The motor accelerates the disk uniformly from rest by exerting a constant torque of 1 n * m
What is the time required for the disk to reach an angular speed of 800 rpm
tor = i a
i = rotational intertia
a = acc
So I convert 800 rotations / min to 80/6 rotations a second.
since angular acceleration = Torque / rotational interta, and I have torque is 1 n * m and rotational intertia = (1/2) m r^2
so I have (1) / (1/2)(3)(.22)^2 = 13.77
so that should be my angular acceleration right?
Now to find time all I have to do is use euqation
[itex] W_0 + ax t = W_x [/itex]
w_o = 0 so
t = (W_x)/(a_x)
t = 80/(6)(13.77) = .9682 s
but my books answer was 6.08 seconds.
Does anyone know where I went wrong? I have a feeling I calculated acceleration wrong :/
Wrong. That looks like the moment of inertia.
Wow.. you are right.
So angular acc = I / Torque
so acc = (1/2)mr^2 = (1/2) (3) (.22)^2
But doing this I got angular acc = .0726 rad /s^2
Now using w_0 + ax t = wx
I get t = wx/ax = (80/6) (1/.0726) which = 183.65 which is still the wrong answer??
Incorrect. It would help if you got into the habit of appending units to any number you write down. What are your units in this case?
Sorry I will do that from now on.
https://www.boundless.com/physics/textbooks/boundless-physics-textbook/static-equilibrium-elasticity-and-torque-8/torque-and-angular-acceleration-80/relationship-between-torque-and-angular-acceleration-319-6062/
This page makes the statement "Torque is equal to the moment of inertia times the angular acceleration."
moment of intertia = (1/2)MR^2 and torque = 1 N m
Why can't I set angular acceleration = Torque / moment of intertia?
You can. What you had before is the inverse of that. You have to be careful because small things like that will trip you up. Now can you finish the problem?
I'm not sure :(
So I can state "acceleration = Torque / moment of intertia"
torque was given to be 1 N * m
moment of intertia given by my book is (1/2)MR^(2) = (1/2)(3kg)(.22m)^2 = .0736 kg m^2
so 1 N / .0736 kg m = 13.77 N/ (kgm) = acceleration
What am I missing? Why is this still the wrong acceleration value?? I'm literally plugging the values right into the equation I don't understand how it could be wrong..
You are missing the correct units for the acceleration. You list them as N/(kg m). Is that what they are? What does your textbook say they ought to be?
Edit: The number 13.77 is correct. It's the units you need to understand because that matters for finishing the problem correctly.
I see. I took the following steps and got 13.77 rad/s^2
( (1kg m^2)/(s^2) ) / ( (3kg/2)(.22m)^2 )
= (2) / ( 3 * (.22)^2 ) s^2
= 13.77rad s^(-2)
So is my value for acceleration correct??
Yes it is. Now proceed to find the required time.
Likes Rijad Hadzic
Okay now that I found angular acceleration = 13.77 rad s^(-2)
I use equation
W_o + (angacc)t = W_final
Well I know W_final = 800 rpm (I'm going to assume this to be rotations per minute not radians per minute) so 13.33 rotations per second, 1 rotation = 2pi so
2pi(13.33) rad/s
okay I'm just going to stop here.
I completely get the point you were trying to get to me here.
I got the answer that was written in my book... 6.08 seconds..
I see now. Write down your units. and follow them. Each. And. Every. Time.
Thank you for your patience with me.
Likes kuruman
Good job! :smile:
Related to Time required for disk to reach angular speed?
1. How is the angular speed of a disk measured?
The angular speed of a disk is measured in radians per second. This is the rate at which the disk rotates around its center point.
2. What factors affect the time required for a disk to reach angular speed?
The time required for a disk to reach angular speed is affected by the moment of inertia of the disk, the torque applied to the disk, and any external forces acting on the disk.
3. Can the time required for a disk to reach angular speed be calculated?
Yes, the time required for a disk to reach angular speed can be calculated using the formula T=Iα/τ, where T is the time, I is the moment of inertia, α is the angular acceleration, and τ is the torque.
4. How does the size and shape of a disk affect the time required for it to reach angular speed?
The size and shape of a disk can affect the time required for it to reach angular speed. A larger and heavier disk will have a larger moment of inertia, which will require more torque and time to reach a desired angular speed. The shape of the disk also plays a role in determining its moment of inertia.
5. Is the time required for a disk to reach angular speed affected by the material it is made of?
Yes, the material of the disk can affect its time required to reach angular speed. A disk made of a denser material will have a larger moment of inertia, requiring more torque and time to reach a desired angular speed.
10K
9K
