Time Reversal Invariance Of Hamiltonian
Therefore, T cannot be considered a conserved quantity. In summary, although the Hamiltonian is invariant under time reversal, the time-reversal operator T does not represent a conserved quantity. This is because T is an anti-unitary operator and its eigenvalues are not constant and do not commute with the Hamiltonian. Therefore, the expectation value of T is not a conserved quantity and cannot be used as a conserved quantity in a time-reversal invariant system.
casdan1
Suppose that the Hamiltonian is invariant under time reversal: [H,T] = 0. Show that, nevertheless, an eigenvalue of T is not a conserved quantity.
Using Kramer's Theorem.
Consider the energy eigenvalue equation, [tex]H|\Psi\rangle = E|\Psi\rangle[/tex] for a time-reversal-invariant Hamiltonian, TH = HT. Therefore
[tex]HT|\Psi\rangle = TH|\Psi\rangle = ET|\Psi\rangle[/tex], so both [tex]|\Psi\rangle[/tex] and [tex]T|\Psi\rangle[/tex] are eigenvectors with energy eigenvalue E.
This implies two possibilities.
1. [tex]|\Psi\rangle[/tex] and [tex]T|\Psi\rangle[/tex] are linearly dependent, and so describe the same state, or
2. They are linearly independent, and so describe two degenerate states.
It can further be shown that case 1 is not possible in certain circumstances.
How can I show that there is no conserved quantity?
To show that there is no conserved quantity, we can look at the expectation value of the time-reversal operator, T, for the state |\Psi\rangle. If T|\Psi\rangle = |\Psi\rangle, then the expectation value of T for the state will be +1. If T|\Psi\rangle = -|\Psi\rangle, then the expectation value of T for the state will be -1.
Since T is an anti-unitary operator, its eigenvalues are always ±1. This means that for any state |\Psi\rangle, the expectation value of T will always be either +1 or -1, depending on the eigenvalue of T for that state. Therefore, the expectation value of T is not a constant and cannot be considered a conserved quantity.
Furthermore, since T is an anti-unitary operator, it does not commute with the Hamiltonian, [H,T] ≠ 0. This means that the time-reversal operator does not commute with the Hamiltonian and therefore, the eigenvalues of T are not conserved quantities in a time-reversal invariant system.
In conclusion, even though the Hamiltonian is invariant under time reversal, the eigenvalues of the time-reversal operator are not conserved quantities. This is because T is an anti-unitary operator and its eigenvalues are not constant and do not commute with the Hamiltonian.
FAQ: Time Reversal Invariance Of Hamiltonian
1. What is time reversal invariance of Hamiltonian?
Time reversal invariance of Hamiltonian is a fundamental principle in physics that states that the dynamics of a physical system should remain unchanged when time is reversed. This means that if the system evolves from its initial state at time t=0 to a final state at time t=T, then the same system should also evolve from the final state back to the initial state when time is reversed from t=T to t=0.
2. Why is time reversal invariance of Hamiltonian important?
Time reversal invariance of Hamiltonian is important because it is a fundamental symmetry of nature. It allows us to make predictions about the behavior of physical systems and helps us understand the laws of physics at a deeper level. Additionally, it has practical applications in fields such as quantum mechanics and particle physics.
3. How is time reversal invariance of Hamiltonian related to the conservation of energy?
Time reversal invariance of Hamiltonian is closely related to the conservation of energy. This is because if a system is time-reversal invariant, then the energy of the system should remain constant when time is reversed. This is known as the law of conservation of energy, which is a fundamental principle in physics.
4. Can time reversal invariance of Hamiltonian be violated?
In some cases, time reversal invariance of Hamiltonian can be violated. This is usually seen in systems that are not in equilibrium and are subject to external forces. One example of this is the decay of certain subatomic particles, which can violate time reversal invariance due to the weak nuclear force.
5. How is time reversal invariance of Hamiltonian tested experimentally?
Time reversal invariance of Hamiltonian can be tested experimentally through a variety of methods. One common approach is to study the behavior of physical systems under time reversal transformations and compare it to the expected behavior based on the principle of time reversal invariance. Other methods involve studying the symmetries of particles and their interactions or using advanced techniques in quantum mechanics and particle physics.
