Time reversal symmetry and Bloch states
In summary, time reversal is an operator that transforms a Bloch state by taking its complex conjugate. For a system to be time reversal invariant, the wavefunctions with k and -k must be energetically degenerate, allowing for the formation of invariant wavefunctions. However, this only applies to scalar functions and not spinor valued functions like electrons.
Joker93
504
37
Hello!
The time reversal operator, ##\hat{\Theta}## transforms a Bloch state as follows:
##\hat{\Theta} \psi_{nk}=\psi^*_{nk}##.
How does one proceed to prove the condition that ##\psi_{nk}## and ##\psi^*_{nk}## must satisfy in order for our system to be time reversal invariant?
Thanks in advance!
First, i would like to point out that your expression is only correct for scalar functions, but not for spinor valued functions, i.e. electrons.
A Bloch function is proportional to exp(ikr) which becomes exp(-ikr) on time reversal. Hence time reversal converts a state with k into one with -k.
In the scalar case, it will be possible to write down an invariant wavefunction if the wavefunctions with k and -k are energetically degenerate. As you then can form ##\psi_k+\psi_{-k}## and ##i\psi_k-i\psi_{-k}##.
FAQ: Time reversal symmetry and Bloch states
What is time reversal symmetry?
Time reversal symmetry is a fundamental concept in physics that states that the laws of physics should remain the same if time is reversed. This means that if you were to run a physical experiment backwards, the results should be the same as if you ran it forwards.
How does time reversal symmetry relate to Bloch states?
Bloch states are a type of quantum mechanical wave function that describes the behavior of particles in a periodic potential. These states are characterized by their energy and momentum, and they exhibit time reversal symmetry, meaning that they are unchanged when time is reversed.
Can time reversal symmetry be broken?
Yes, time reversal symmetry can be broken in certain situations, such as in systems with strong magnetic fields or in the presence of certain types of interactions. In these cases, the laws of physics may not remain the same when time is reversed.
What are the applications of time reversal symmetry and Bloch states?
Time reversal symmetry and Bloch states have many applications in physics, including the study of condensed matter systems, such as crystals and semiconductors. They also play a crucial role in understanding the behavior of electrons in materials and in the development of new electronic devices.
How do scientists study time reversal symmetry and Bloch states?
Scientists use a variety of experimental techniques, such as scanning tunneling microscopy and angle-resolved photoemission spectroscopy, to study the properties of Bloch states and the effects of time reversal symmetry in different systems. Theoretical models and simulations are also used to understand and predict the behavior of these states.
