Time-shifted Integral with Unit Impulse Function
In summary: EvennessIn summary, the integral \int_{-\infty}^\infty f(2 -t) \delta(3 -t) \, dt can be evaluated by using a u-substitution, where u = 3-t. This results in a change in the integration limits, with u approaching infinity in the lower limit and negative infinity in the upper limit. By using the property of the Dirac delta function that it is even, the minus sign can be eliminated, giving the final answer of f(-1).
Les talons
28
Evaluate the integral.
[tex] \int_{-\infty}^\infty f(2 -t) \delta(3 -t) \, dt [/tex]
The Unit Impulse function is defined
[tex] \hspace{18mm} \delta(0) = 0 \hspace{10mm} t \neq 0 [/tex]
[tex] \hspace{-15mm} \int_{-\infty}^\infty \delta(t) \, dt = 1 [/tex]
Using a u-substitution ##u = 3 -t##, ##dt = -du##, ##t = 3 -u##
[tex] = \int_{-\infty}^\infty f(2 -(3 -u)) \delta(u) (-1) \, du [/tex]
[tex] = -\int_{-\infty}^\infty f(u -1) \delta(u) \, du [/tex]
[tex] = -f(0 -1) [/tex]
[tex] = -f(-1) [/tex]
Please let me know if the above is unclear. My question is 1) Is this the right solution? and 2) Trusted sources tell me that the answer is just ##f(-1)##. Which is the correct answer? Is there some mathematical detail I am missing? Hope this is clear, and hope you can help. ##\mathcal{Thanks}##
You did a substitution of u = 3-t. And so you got a du instead of a dt. Good. What happens to the limits on the integral?
Likes Les talons
Yes, you have changed the integration limits when you did the variable substitution. ##u\to -\infty## when ##t\to +\infty##
Likes Les talons
For the lower limit of the integral, since ##t \rightarrow -\infty##, ##u \rightarrow 3 -(-\infty) \rightarrow 3 +\infty \rightarrow \infty##, and in the upper limit of the integral, ##t \rightarrow \infty##, implying ##u \rightarrow 3 -\infty \rightarrow -\infty##. The net effect is to annihilate the ##-1## in front of the integral, giving the evaluation ##f(-1)##. Thank you both for the insight!
Likes Les talons
FAQ: Time-shifted Integral with Unit Impulse Function
What is a time-shifted integral?
A time-shifted integral is a mathematical operation that involves finding the area under a curve that has been shifted along the time axis. This means that the curve is moved horizontally, either to the right or left, before the integration is performed.
What is a unit impulse function?
A unit impulse function, also known as a Dirac delta function, is a mathematical function that is defined to be zero everywhere except at one specific point, where it is infinitely large. It represents a very narrow pulse or spike in a function.
How are time-shifted integrals and unit impulse functions related?
Time-shifted integrals and unit impulse functions are related because the area under a time-shifted function can be expressed as a sum of unit impulse functions. This is known as the time-domain convolution theorem.
What is the significance of using a unit impulse function in a time-shifted integral?
The use of a unit impulse function in a time-shifted integral allows us to simplify complex functions and analyze them in the time domain. It also allows us to determine the output of a system when given an impulse input.
How are time-shifted integrals with unit impulse functions used in real-world applications?
Time-shifted integrals with unit impulse functions have many practical applications in fields such as signal processing, control systems, and image processing. They are used to model and analyze systems with time-varying inputs, such as audio signals or electrical circuits.
