Time to Max Compression of a Spring
In summary, the conversation discusses the time it takes for a block to reach maximum compression after sliding down an incline and colliding with a spring. The solution involves using conservation of energy and integrating to find the time, which is found to be independent of gravity and height. It is also noted that this time corresponds to one-fourth of the period of simple harmonic motion.
kq6up
368
[/B]
A block of mass m slides down an incline with a height h. Later, it collides with a spring and compresses the spring to some maximum displacement. How long does it take to reach maximal compression.
[/B]
1) ##mgh=\frac{1}{2}mv^2+\frac{1}{2}kx^2##
2) ##
t=\int _{0}^{ x_{max}}{\frac{1}{v}}{dx }
[/B]
By conservation of energy:
##mgh=\frac{1}{2}mv^2+\frac{1}{2}kx^2## Rearranging to solve for ##v##:
##v=\sqrt{2gh-\frac{k}{m}x^2}##
Inserting into 2):
##t=\int _{0}^{ x_{max}}{\frac{1}{\sqrt{2gh-\frac{k}{m}x^2}}}{dx }##
This is in the form:
##\int { \frac { 1 }{ \sqrt { a^{ 2 }-u^{ 2 } } } } { du }=\sin ^{ -1 } \frac { u }{ a } ##
Using the appropriate substitution we get:
##t=\sqrt { \frac { m }{ k } } \left[ \sin^{-1} \frac{u}{a} \right]_{0}^{\sqrt{\frac{k}{m}}x} ##
Where: ##a=\sqrt{2gh}## and ##x_{max}=\sqrt{\frac{2mgh}{k}}##
Yields the result:
##t=\sqrt{\frac{m}{k}}\frac{\pi}{4}##
Does this look correct? The result is independent of gravity and height of the initial mass.
Thanks,
kQ6Up
Almost correct. Have you studied simple harmonic motion? If so, what fraction of the period is the time from equilibrium to maximum displacement?
Likes kq6up
Ah, I see that it would be ##\frac{T}{4}##, and that would be ##\sqrt{\frac{m}{k}}\frac{\pi}{2}## I see my error. I confused ##\sin^{-1}1## with ##\tan^{-1}1## which was an earlier result.
Thank you,
kQ6Up
Related to Time to Max Compression of a Spring
1. What is the definition of "Time to Max Compression of a Spring"?
The "Time to Max Compression of a Spring" refers to the amount of time it takes for a spring to reach its maximum compressed state after being subjected to an external force.
2. How is the "Time to Max Compression of a Spring" measured?
The "Time to Max Compression of a Spring" is typically measured in seconds using a stopwatch or a timer. It can also be calculated using mathematical equations, depending on the specific properties of the spring and the external force applied.
3. What factors affect the "Time to Max Compression of a Spring"?
The "Time to Max Compression of a Spring" can be affected by several factors, including the stiffness of the spring, the magnitude of the external force, and the initial position of the spring.
4. How does the "Time to Max Compression of a Spring" relate to the spring constant?
The "Time to Max Compression of a Spring" is inversely proportional to the spring constant, meaning that as the spring constant increases, the time to reach maximum compression decreases.
5. Can the "Time to Max Compression of a Spring" be changed or controlled?
Yes, the "Time to Max Compression of a Spring" can be changed by altering the properties of the spring, such as its stiffness or length, or by adjusting the external force applied to the spring.
