Time-Varying Cosmological Constant Implications in GR
In summary, the cosmological constant remains constant in GR only if the ordinary energy-momentum tensor is also conserved, which may require non-standard theories such as scalar-tensor theories.
fhenryco
63
Hi,
I want to be sure i understand correctly the implications of problem 2 in:
http://universeinproblems.com/index.php/Time-dependent_Cosmological_Constant
"when G is constant, Lambda is also a constant if and only if the ordinary energy-momentum tensor Tμν is also conserved "
As far as i know the ordinary energy momentum tensor covariant conservation is granted as soon as the corresponding fields :
1) have their own scalar action
2) are fully dynamical in this action e.g. their equations of motion are derived from them extremizing the action
so the case corresponding to a cosmological constant and matter fields exchanging energy (subject of next problem 3 ) implicitely imply that either the theory is not diffeomorphism invariant (1 not satisfied: which for me does not make any sense) or somehow the dynamics of the matter fields does not only follow from the action e.g. the fields are not completely dynamical in the usual sense: this is a bit less shocking for me ... but still very unusual
Do others confirm i understand correctly the implications of a time varying cosmological constant in GR ?
Hello,
You are correct in your understanding of the implications of a time-varying cosmological constant in general relativity (GR). In order for Lambda (the cosmological constant) to remain constant, the ordinary energy-momentum tensor Tμν must also be conserved. This means that the fields in the theory must have their own scalar action and be fully dynamical, as you mentioned.
However, as you pointed out, the case of a cosmological constant and matter fields exchanging energy (problem 3 in the link) raises some questions about the diffeomorphism invariance of the theory. This is because the matter fields would have to be non-dynamical or their dynamics would have to be determined by something other than the action, which goes against the principles of GR.
Some theories, such as scalar-tensor theories, do allow for a time-varying cosmological constant while still maintaining diffeomorphism invariance. In these theories, the scalar field is responsible for the dynamics of both the cosmological constant and matter fields. However, these theories are still not widely accepted and remain an active area of research.
In conclusion, your understanding of the implications of a time-varying cosmological constant in GR is correct. It does raise some questions about the diffeomorphism invariance of the theory, but there are some alternative theories that can accommodate a time-varying cosmological constant while maintaining this principle.
Related to Time-Varying Cosmological Constant Implications in GR
1. What is a time-varying cosmological constant and how does it impact general relativity?
A time-varying cosmological constant is a term in the Einstein field equations of general relativity that represents the energy density of the vacuum of space. This constant is a crucial component in the theory of the expansion of the universe. When it varies over time, it affects the rate of expansion and can potentially explain the observed acceleration of the expansion of the universe.
2. What evidence supports the existence of a time-varying cosmological constant?
The most compelling evidence for a time-varying cosmological constant comes from observations of distant supernovae. These observations show that the universe is expanding at an accelerating rate, which can be explained by a time-varying cosmological constant.
3. How does a time-varying cosmological constant impact the study of dark energy?
Dark energy is a mysterious force that is thought to be responsible for the observed acceleration of the expansion of the universe. A time-varying cosmological constant is one possible explanation for dark energy and studying its implications in general relativity can help us better understand this elusive force.
4. Can a time-varying cosmological constant help resolve the cosmological constant problem?
The cosmological constant problem is the issue of why the observed value of the cosmological constant is so much smaller than the predicted value based on quantum field theory. A time-varying cosmological constant may offer a solution to this problem, as it allows for the value of the constant to change over time and potentially align with observations.
5. What are some potential implications of a time-varying cosmological constant in our understanding of the universe?
A time-varying cosmological constant has the potential to significantly impact our understanding of the universe and its evolution. It could help explain the observed acceleration of the expansion of the universe, shed light on the nature of dark energy, and provide a solution to the cosmological constant problem. Additionally, studying its implications in general relativity may lead to new insights and discoveries in cosmology.
  • Astronomy and Astrophysics
