Time varying magnetic field in conductors
This is known as electromagnetic induction and is a fundamental principle in electromagnetism. In summary, the decoupling of magnetic and electric fields in the static case is why EM waves do not penetrate much in metals, but in the case of time varying fields, both fields are linked and can exist together, as seen in transformer cores through electromagnetic induction.
Thierry
Hi
Something is bugging me a little. According to Maxwell's equations the magnetic and electric fields are decoupled in the static case, so that magnetic fields can exist in metals but not electric fields. For time varying fields, though, both fields are linked so that one cannot exist without inducing the other. That's why EM waves don't penetrate much in metals. So how come there can be strong oscillating magnetic fields in transformer cores? What's happening to the accompanying electric field?
Cheers
The electric field accompanying the strong oscillating magnetic field in a transformer core is very small and is cancelled out by the electrical insulation between the primary and secondary coils. This is why electromagnetic waves do not penetrate much in metals. The oscillating magnetic field in the transformer core is the result of the alternating current flowing through the primary coil, which induces a magnetic field in the core that interacts with the secondary coil, inducing an alternating current in it.
Related to Time varying magnetic field in conductors
What is a time varying magnetic field in conductors?
A time varying magnetic field in conductors refers to a changing magnetic field that is induced in a conductor, such as a wire, due to a time-varying current passing through it. This phenomenon is described by Faraday's Law of Induction and is the basis for many electrical devices.
How is a time varying magnetic field created in conductors?
A time varying magnetic field can be created in conductors by either moving a magnet relative to the conductor or by changing the current passing through the conductor. This causes a change in the magnetic flux through the conductor, which in turn induces an electric field and a corresponding time varying magnetic field.
What are the effects of a time varying magnetic field in conductors?
A time varying magnetic field in conductors can cause a phenomenon known as electromagnetic induction, where the changing magnetic field induces an electric current in the conductor. This is the basis for many electrical devices, such as generators and transformers.
How does a time varying magnetic field affect the behavior of conductors?
A time varying magnetic field can induce an electric current in conductors, which can cause a variety of effects depending on the characteristics of the conductor and the magnetic field. For example, the induced current can create heat, generate light, or produce a magnetic field of its own.
What are some real-world applications of time varying magnetic fields in conductors?
Time varying magnetic fields in conductors are used in a wide range of technologies, including generators, transformers, motors, and electromagnetic sensors. They are also essential in the functioning of household appliances, power grids, and many other electrical devices.
  • Electromagnetism
  • Electromagnetism
