Time-varying magnetic field outside a solenoid
In summary, a solenoid is a coil of wire that creates a magnetic field when an electric current passes through it. The magnetic field is strongest at the center and can be turned on and off or varied in strength. A time-varying magnetic field outside a solenoid changes over time, while a constant magnetic field remains the same. Factors such as the number of turns, current, and core material can affect the strength of the magnetic field. The direction of the magnetic field outside a solenoid changes as the current passing through the coil changes, resulting in a cyclical pattern. Some applications of a time-varying magnetic field outside a solenoid include speakers, motors, generators, medical imaging, wireless charging, and
trix312
something that has had me confused:
How can I calculate the time varying magnetic field produced by a solenoid, outside the solenoid along the axis of the core. I know that:
inside the solenoid : apply amperes law
For DC (magnetostatic) case outside the solenoid : apply Biot-savart law
but what about a AC (time varying field) outside the solenoid? is the attenuation calculated like in EM waves attenuation and skin-depth? I also read something about replacing biot-savart with Jefimenko's equations if magnetostatics does not apply. Or is this not possible to calculate analytically.
What is going on?
Calculating the time varying magnetic field produced by a solenoid outside the solenoid along the axis of the core can be a complex and confusing task. However, there are several approaches that can help you understand and calculate this field.
As you mentioned, for the DC (magnetostatic) case, you can apply Ampere's law inside the solenoid. This law states that the line integral of the magnetic field around a closed loop is equal to the current passing through that loop. This approach works well for steady currents, but for time varying fields, it becomes more complicated.
For the AC case, you can use the Biot-Savart law, which relates the magnetic field at a point to the current element at that point. This law can be used to calculate the magnetic field outside the solenoid along the axis of the core. However, this approach also becomes more complicated for time varying fields, as it requires calculating the magnetic field at each point along the axis.
Another approach is to use Jefimenko's equations, which take into account the time varying nature of the field. These equations can be used for both the inside and outside of the solenoid, and they take into account the displacement current, which is important for time varying fields. However, these equations can be quite complex and may not be easily solvable analytically.
In terms of attenuation, the approach will depend on the frequency of the time varying field. For low frequencies, the attenuation can be calculated using the skin depth, which is the depth at which the amplitude of the field is reduced by a factor of e. For higher frequencies, the attenuation will depend on the material properties and the frequency of the field.
In summary, calculating the time varying magnetic field outside a solenoid can be a challenging task. Depending on the frequency and complexity of the field, different approaches can be used, such as Ampere's law, Biot-Savart law, or Jefimenko's equations. It is important to consider the displacement current and material properties when calculating the attenuation of the field. I hope this helps clarify some of your confusion.
Related to Time-varying magnetic field outside a solenoid
What is a solenoid?
A solenoid is a coil of wire that is used to create a magnetic field when an electric current passes through it. It is typically cylindrical in shape and has a magnetic field that is strongest at its center.
How does a time-varying magnetic field outside a solenoid differ from a constant magnetic field?
A time-varying magnetic field outside a solenoid is one that changes in strength or direction over time, while a constant magnetic field remains the same. This means that the magnetic field produced by a solenoid can be turned on and off or varied in strength, while the magnetic field of a permanent magnet remains constant.
What factors can affect the strength of the magnetic field outside a solenoid?
The strength of the magnetic field outside a solenoid can be affected by several factors, including the number of turns in the coil, the amount of current passing through the coil, and the material of the core (if present). Increasing the number of turns or the current will increase the strength of the magnetic field, while adding a core made of a ferromagnetic material can further enhance the field.
How does the direction of the magnetic field outside a solenoid change with time?
The direction of the magnetic field outside a solenoid changes as the current passing through the coil changes. When the current is increasing, the magnetic field will be in one direction, and when the current is decreasing, the field will be in the opposite direction. This means that the magnetic field outside a solenoid is always changing direction in a cyclical pattern as the current varies.
What are some applications of a time-varying magnetic field outside a solenoid?
A time-varying magnetic field outside a solenoid is used in a variety of applications, including as an electromagnet in speakers, motors, and generators. It is also used in medical imaging technology, such as MRI machines, to create detailed images of the body. Additionally, time-varying magnetic fields are used in wireless charging technologies and in particle accelerators for scientific research.
