Time, velocity, deceleration and the constant K
In summary, you are trying to find the value of a design parameter, K, for a landing gear vane that plows through water at a speed of 24 mi/hr. You solve for K using first principles, and find that the value is 0.01162. The time it takes for the aircraft to travel 1370 ft is 12.845 seconds.
Northbysouth
249
A certain lake is proposed as a landing area for large jet aircraft. The touchdown speed of 110 mi/hr upon contact with the water is to be reduced to 24 mi/hr in a distance of 1370 ft. If the deceleration is proportional to the square of the velocity of the aircraft through the water, a = -Kv2, find the value of the design parameter K, which would be a measure of the size and shape of the landing gear vanes that plow through the water. Also find the time t elapsed during the specified interval.
x = x0 + v0xt + 1/2at2
v = v0x + at
v = v0x + at
24 mi/hr = 110 mi/hr - (kv2)t
24 mi/hr = 110 mi/hr -576kt
576kt = 86 mi/hr
t = 86/576k
Taking this I plugged it into
1370ft = 0 + (110mi/hr)t + 1/2(-kv2)t2
Plugged in v = 24 mi/hr
1370ft = (110 mi/hr)5 - 288 kt2
1370 ft = (110 mi/hr)(86/576k) - 288(86/576)
k = 0.01162
t = 12/845
I realize that I entered my value for k into the system incorrectly, but I used that value to calculate t, which was incorrect. With that said, I'm not sure what to do. Suggestions are welcome and appreciated. THanks
v = v0x + at
v = v0x + at
576kt = 86 mi/hr
It is best to solve all problems symbolically before plugging in any numbers. Each time one plugs in a number, one loses information that can help solve the problem or check one's answer for sanity.
However, your difficulty here is that the equations you are using only apply when the acceleration is constant, whereas in this problem the acceleration depends on velocity. You have to start from first principles, that is, the definitions of velocity and acceleration.
When you say first principles do you mean:
v = dx/dt
a = dv/dt = dv/dx*dx/dt = v dv/dx
Will I need differential equations to solve this problem?
v = dx/dt
Yes. This one is correct.
This one starts out correctly, but then goes astray:
[tex]a = \frac{dv}{dt} = \frac{d^2x}{dt^2}[/tex]
No; simple integration is enough.
You are given
[tex]a = \frac{dv}{dt} = -Kv^2.[/tex]
Start from there.
I would like to point out that the design parameter K is not solely a measure of the size and shape of the landing gear vanes, but also a measure of the drag and resistance of the aircraft through water. The value of K will depend not only on the size and shape of the vanes, but also on the specific design of the aircraft and its materials.
In terms of the solution, it seems that you have made some errors in your calculations. I would suggest revisiting your equations and making sure to use consistent units (miles vs. feet) throughout. Additionally, you may want to double check your substitution of values and use of the quadratic formula. It may also be helpful to plot the given information on a graph and use the slope to find the value of K.
Overall, this is an interesting problem that highlights the importance of considering various factors when designing a landing area for aircraft. As a scientist, it is important to carefully consider all aspects and variables in a problem and make accurate calculations based on sound equations and principles.
Related to Time, velocity, deceleration and the constant K
1. What is the concept of time in science?
Time in science is often described as the measurement of the duration between two events. It is a fundamental aspect of the universe and is used to understand the order of events and the rate at which they occur.
2. How is velocity defined in science?
Velocity is a measurement of the rate and direction of an object's movement. It is a vector quantity, meaning it has both magnitude and direction. In science, velocity is typically measured in units of distance over time (e.g. meters per second).
3. What is deceleration and how is it different from acceleration?
Deceleration is the opposite of acceleration and refers to the decrease in an object's velocity over time. It is often used to describe the slowing down of an object due to external forces, such as friction or air resistance. Acceleration, on the other hand, refers to the increase in an object's velocity over time.
4. What is the constant K and how is it used in scientific equations?
The constant K, also known as the universal gas constant, is a fundamental physical constant that relates the properties of a gas to its temperature, pressure, and volume. It is used in various scientific equations, such as the ideal gas law, to calculate the behavior of gases under different conditions.
5. Can the concept of time travel be explained using these scientific principles?
While the concept of time travel is a popular topic in science fiction, it is not currently possible according to our current understanding of time, velocity, deceleration, and the constant K. However, scientists continue to explore and study these concepts in hopes of unlocking the mysteries of time and the universe.
11K
9K
9K
10K
