Times New Roman for a portion of a ##\rm{\LaTeX}## document
  • LaTeX
  • Thread starter brotherbobby
  • Tags
    Font Latex
In summary, using Times New Roman in a portion of a LaTeX document can be achieved by employing the `fontspec` package with XeLaTeX or LuaLaTeX, which allows for easy font customization. By specifying Times New Roman in the preamble or within a specific environment, you can format text accordingly. Additionally, the `\setmainfont` command can be used for the overall document, while `\fontspec` can apply the font to specific sections or text. This flexibility enables clearer and more aesthetically pleasing document presentation.
brotherbobby
702
163
TL;DR Summary
Can a portion of a document in ##\rm{\LaTeX}## be converted into the well known ##\verb|Times New Roman|## font?
I am writing a document (article) in ##\rm{\LaTeX}##. Due to easier reading and differentianting a portion of the text from the rest, it is necessary for me to use some other font and I have chosen the ##\verb|Times New Roman|##. However, I don't know how to go about it.
Are there any packages? Is there a font code for the Times New Roman font that I'd need to specify for the portion in question?
Many thanks.
If you are ok with Times, you can simply use
Code:
{\fontfamily{ptm}\selectfont
This text is typeset in Times.
Thank you at @DrClaude.
So the ##\rm{LaTeX}## font code for the ##\verb|Times|## font is {ptm}. One simply has to know it.
Do you know where can I find a list of fonts I can use in ##\rm{LaTeX}## with the font code?
Thank you @DrClaude. Actually, upon a bit of search, I found an even better catalogue of ##\rm{LaTeX}## fonts online : LaTeX Fonts .
I suppose a huge difference with ##\text{MSWord}^{\circledR}## is that over there I can install fonts on my computer (as .ttf or .otf) and just select them from the drop down menu when I type. In ##\rm{\LaTeX}## however, there's no such thing. If a font you want doesn't exist, you have to do without it.
Likes DrClaude
FAQ: Times New Roman for a portion of a ##\rm{\LaTeX}## document
How can I change the font to Times New Roman for a portion of my \(\rm{\LaTeX}\) document?
You can use the \texttt{fontspec} package along with \texttt{\textbackslash textsf} command to change the font. For example, \texttt{\textbackslash textsf\{Times New Roman\}} will change the font to Times New Roman for the enclosed text.
Do I need to install any specific package to use Times New Roman in \(\rm{\LaTeX}\)?
Yes, you need to install the \texttt{fontspec} package, which allows you to use system fonts like Times New Roman in \(\rm{\LaTeX}\). Make sure you are using XeLaTeX or LuaLaTeX as your compiler.
Can I use Times New Roman for both text and math in my \(\rm{\LaTeX}\) document?
Yes, you can use the \texttt{mathspec} package along with \texttt{fontspec} to set Times New Roman for both text and math. Use the \texttt{\textbackslash setmathfont} command to specify the math font.
How do I ensure that only a specific section of my document uses Times New Roman?
You can use the \texttt{\textbackslash begin\{fontfamily\}\{Times New Roman\}\textbackslash selectfont} and \texttt{\textbackslash end\{fontfamily\}} commands to limit the scope of the font change to a specific section.
Is it possible to revert back to the default font after using Times New Roman for a portion of the document?
Yes, you can revert to the default font by using \texttt{\textbackslash end\{fontfamily\}} or by specifying the original font family using the \texttt{\textbackslash textsf} or \texttt{\textbackslash texttt} command with the appropriate font name.
9K
41K
