Timescale of virtual photon interaction in particle scattering
In summary: Overall, the key concept to understand is that the uncertainty principle limits the precision with which we can measure certain physical quantities, and this has important implications for the time-scales of interactions between particles.
Lux137
TL;DR Summary
Why is the time-scale of the virtual photon exchange τ~1/Q in two particle scattering?
I'm studying the electron-proton deep inelastic scattering. In the notes that I'm studying from the author states that the time-scale for a virtual photon to interact with a proton is ##τ\sim\frac{1}{Q}##, where ##Q## is the momentum transfer with ##Q\gg M##, which is the mass of the proton. I assume by ##Q## he means the Minkowski norm of the 4-momentum transfer. And then he compares it with the time-scale of the quarks interaction in a proton ##τ\sim\frac{1}{M}##. All this in a reference frame where the proton is at rest.
Later on delving more into time-scales he writed that the typical time of interaction of an electron with a virtual photon is also ##\frac{1}{Q}## which is to be compared with the time the electron emits and reabsorb its own virtual photons ##\frac{1}{q}##
I'm having a very hard time justifying all these time-scale estimations by myself. I tried to apply the time evolution on a state with an electron and a photon, as eigenstates of the free hamiltonian ##H_0## (not the full ##H=H_0+H_i##) in the interaction picture, in order to visualize what happens with virtual particles, and what i got is that the amplitudes for scattered states reach its max at ##t\sim\frac{1}{ΔE}## where ##ΔE## is the difference between the virtual photon energy and the energy it would have if it were on-shell. Which is still different from the statements above.
I can't seem to get past this and i feel like it's something silly that i should have already grasped, since in all the textbooks i have checked the topic of interaction time-scale is always barely mentioned or completely skipped. Does anyone know a derivation of these results or maybe some sources where i can find this topic discussed in detail?
Sorry for my bad english.
The time-scale concepts you are discussing are related to the uncertainty principle. In essence, the uncertainty principle states that the more precisely we measure one physical quantity, the more uncertain we will be about another physical quantity. In particular, the position-momentum uncertainty principle states that the uncertainty in the position of an object multiplied by the uncertainty in its momentum must be greater than or equal to a certain constant (usually denoted by ħ). This means that if we know the momentum of an object very precisely, then we cannot know its position equally precisely, and vice versa.In the case of electron-proton deep inelastic scattering, this means that if the momentum transfer is very large (i.e. Q is much larger than the proton's mass M), then we can only be certain that the virtual photon interacted with the proton for a short amount of time. The time-scale for this interaction is approximately 1/Q. On the other hand, if the momentum transfer is small (i.e. Q is much smaller than the proton's mass M), then the time-scale for the interaction is approximately 1/M.Similarly, the time-scale for the interaction between an electron and a virtual photon is approximately 1/Q, while the time-scale for the electron to emit and reabsorb its own virtual photons is approximately 1/q.In order to understand these time-scales better, it may be helpful to look at some diagrams of the scattering process. You can find some diagrams in the following references: 1. S. D. Ellis, "Deep Inelastic Scattering", Cambridge University Press, 2001.2. P. E. Nishijima, "Quantum Mechanics of Particles and Fields", World Scientific, 1994.
Related to Timescale of virtual photon interaction in particle scattering
What is the timescale of virtual photon interaction in particle scattering?
The timescale of virtual photon interaction in particle scattering depends on the energy of the particles involved. At lower energies, the timescale can range from femtoseconds to nanoseconds, while at higher energies, it can range from picoseconds to even shorter timescales.
How does the timescale of virtual photon interaction affect particle scattering experiments?
The timescale of virtual photon interaction is crucial in understanding the dynamics of particle scattering. It determines the time resolution of experiments and affects the accuracy of measurements. Therefore, it is an important factor to consider in designing and analyzing particle scattering experiments.
What factors influence the timescale of virtual photon interaction in particle scattering?
The timescale of virtual photon interaction is influenced by several factors, including the energy and momentum of the particles, the distance between them, and the strength of the interaction between them. Other factors such as the presence of other particles and the environment can also play a role.
How is the timescale of virtual photon interaction related to the concept of virtual particles?
The timescale of virtual photon interaction is closely related to the concept of virtual particles. Virtual particles are particles that exist for a very short time, and their existence is allowed by the uncertainty principle. In particle scattering, virtual photons are exchanged between particles, and their timescale of interaction is determined by the uncertainty principle.
Can the timescale of virtual photon interaction be measured directly?
No, the timescale of virtual photon interaction cannot be measured directly. It is a theoretical concept that is used to understand and describe the behavior of particles in scattering experiments. However, it can be indirectly inferred from experimental data and theoretical calculations.
