Timing in entanglement investigations
In summary, the discussion revolves around experimental investigations of quantum entanglement, specifically how correlated properties between particles are revealed upon measurement. This requires precise timing methods and techniques such as coincidence windows to pinpoint the exact moment of detection. The experiments have been successful in showing instantaneous or extremely rapid influence, but the exact details and interpretation of what happens before detection are still being studied. These experiments have been carried out using photon polarization and have been tested at increasingly longer distances with promising results.
Dadface
2,489
105
Hello all,
I'm trying to get clarification about the experimental investigation of quantum entanglement and I am stuck on one main thing. How is it shown that the correlated properties between particle properties can be revealed instantaneously(or extremely rapidly) upon making the appropriate measurement on one of the particles?
Amongst other things this requires extremely precise timing methods.There are other problems such as how do we specify the exact time that Alice makes her measurements and Bob makes his?
I have spent a fair bit of time searching this but to no avail.
Thank you.
Either I'm misunderstanding your question or you have wrong ideas about quantum entanglement.
Nothing is shown instantaneously(or extremely rapidly) in quantum entanglement experiments. And certainly nothing is revealed after measurement of only one of the particles.
To find coincidences you use so called coincidence window. And speaking about timing we have very accurate clocks - where is the problem?
I would say that bigger problem for timing is detector jitter.
Time transfer for a precise reference time is not extremely difficult these days, and in the linked paper they utilized laser synchronization with a timing accuracy better than 1 ns, while the coincidence window was 3 ns = nema problema.
Of course there are other relativistic situations (moving detectors) where it is theoretically impossible to define simultaneity because of RoS. However, entanglement works as smooth as any other day in the week... don’t ask me how/why because I have absolutely no idea... :rolleyes:
Likes 1 person
Thank you Jilang and DevilsAvocado. That's clarified things for me. One ns and three ns is pretty impressive.
Thank you also zonde but your first paragraph seems to contradict what I have read so far. What I was interested in is details of the experimental techniques used and the results obtained.For the time being I don't think I have any further problems on this.
Dadface said:
I have some familiarity with coincidence techniques but what I want to know is how can we pin down, if at all, the exact moment of detection. For example suppose we measured spin, perhaps by a Davisson /Germer technique.When exactly is the spin detected. Is it when the particles first enter the B field,or when they are first incident on some sort of detecting screen or at any other time?
In general, we can't pin down the exact moment of detection without pinning down the exact point of detection, and that's limited by the size of the detector ("The detection happened somewhere in this volume of space, so happened somewhere between these two points in time"). That's why we spea in terms of detection "windows". When we separate the detectors by a distance that is large compared with the size of the detectors then the travel time is large compared with the window size, so we don't have to worry about it.
Likes 1 person
Dadface said:
I may be misunderstanding something but from what I have been reading if an appropriate measurement is performed on one system then there is an instant (or extremely rapid) influence on any other system with which it is entangled.
Maybe. But surely nothing like that can be directly revealed in entanglement experiments. And your question was about experiments, right?
I would propose to speak about entanglement of photon polarization as experiments with this type of entanglement are most advanced.
Now if we would speak about polarization of photon you learn about polarization when photon is detected in detector. What happens before detection is subject to interpretation.
Closed for moderation. EDIT: and reopened.
Thank you. It seems that increasingly longer distances have been tested and are planned so the size of the detectors becomes less significant.Interesting stuff.
1.I'm still reading up on the experiments that have been carried out so far and the results seem to support the idea that a measurement on one particle instantly collapses the state of the other particle. I haven't seen anything to the contrary yet.
2.The remarks I made previously apply to polarisation as well as to spin (and other correlated properties...if any)
This is a really fascinating area of experimentation. Please keep us posted with any new developments you come across!
Dadface said:
Hello all,
Thank you.
time ordering or time detection ?
Now that's a completely different question! The time ordering depends on your frame of reference... Do you really want to go there?
Dadface said:
How is it shown that the correlated properties between particle properties upon making the appropriate measurement on one of the particles?
Thought not.
Class. Quantum Grav. 29 224011
http://arxiv.org/abs/1206.4949
"So the motivation of the fast moving observers experiment is that each observer would have a different notion of what that moment in time is, according to special relativity. If the two satellites that are making the measurements are approaching each other at relativistic speeds, then an observer on each satellite would have the opinion that their measurement took place before the measurement of the other observer. If we wanted to take quantum mechanics literally then there is an open question—a paradox of sorts—as to what would happen in this situation. Future experiments could test this paradox and see how nature behaves in such a scenario."
Thanks. I wanted to know about the time interval,if any, between observing one of the particles and the other particle. I think I have the answers I need.
FAQ: Timing in entanglement investigations
What is timing in entanglement investigations?
Timing in entanglement investigations refers to the precise synchronization of actions and measurements in experiments that study the phenomenon of quantum entanglement. This involves controlling the timing of entanglement generation, manipulation, and detection in order to accurately measure the state of the entangled particles.
Why is timing important in entanglement investigations?
Timing is important in entanglement investigations because quantum entanglement is a fragile phenomenon that can easily be disrupted by external influences. Therefore, precise timing is necessary to ensure the entanglement remains intact and can be reliably measured.
How is timing controlled in entanglement investigations?
Timing in entanglement investigations is typically controlled using advanced equipment and techniques such as timing generators, phase-locked loops, and high-speed electronics. These tools allow for precise synchronization of actions and measurements on the quantum level.
What challenges are faced in controlling timing in entanglement investigations?
One of the main challenges in controlling timing in entanglement investigations is the potential for external disturbances to disrupt the entangled particles and affect the accuracy of the measurements. This requires careful shielding and isolation of the experimental setup to minimize these disturbances.
How does timing impact our understanding of entanglement?
The precise control of timing in entanglement investigations is crucial for accurately measuring the state of entangled particles and verifying the predictions of quantum mechanics. This allows us to gain a deeper understanding of the nature of quantum entanglement and its potential applications in areas such as quantum computing and communication.
