Timing Marks on Engine, Timing Chain - Conceptual Question
The timing chain's colored links must align with engine timing marks to ensure proper synchronization between the crankshaft and camshaft. This synchronization is crucial for the correct timing of valve openings and closings in relation to piston positions. If the timing marks are not aligned, even though the same chain is used, the engine can experience issues such as misfiring or mechanical failure. Proper alignment reduces the need for precise adjustments during reassembly and prevents uneven wear on the chain or belt. Understanding the mechanical implications of timing marks is essential, especially in interference engines where incorrect timing can lead to severe damage.
YoshiMoshi
TL;DR Summary
Why do you need to to line up the timing marks?
On an engine, the timing chain has colored links, and you have to line up these colored links on timing marks on the engine. There's typically marks on sprockets, bearing caps, gears.
A understand that you have to line these up in order to get proper timing. I understand that is the reason why, but conceptually why does not doing so result in the engine not getting properly timed? I do not understand conceptually what is mechanically different, as it's still the same timing chain that is of the length, going around the same sprockets.
The timing chain synchronize the rotation of the crankshaft and the camshaft. This synchronisation ensures that the engine's valves open and close at the correct times in relation to the position of the pistons. (source)
It is the same chain, or the same timing belt, so the marks on the belt or chain do not have to be correct. So long as the correct number of links, or steps are between the pulley timing marks, it will work. It is easier to get it right the first time if the chain or belt is marked. Marked links reduce the accuracy that the pulleys must be lined up with the engine block or head marks during reassembly.
There will be a factor of two between the crank and the cam. If the length of the belt, in links or steps, does not share prime factors with the crank or cam gear, then the chain or belt will wear evenly once the engine is started. That is the equivalent of a hunting tooth in a gear train.
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved. He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
TL;DR Summary: Heard in the news about using sonar to locate the sub Hello : After the sinking of the ship near the Greek shores , carrying of alot of people , there was another accident that include 5 tourists and a submarine visiting the titanic , which went missing Some technical notes captured my attention, that there us few sonar devices are hearing sounds repeated every 30 seconds , but they are not able to locate the source Is it possible that the sound waves are reflecting from...
