Tipler/Mosca significant figures
In summary, when adding or subtracting numbers, the result can only have a maximum number of significant figures beyond the decimal place as the number with the least number of significant figures beyond the decimal place in the given numbers. This rule does not apply to multiplication and division. To find the correct number of significant figures in the result, it is important to keep track of significant figures at each step of the calculation and round only for the final reported result.
walking
73
In tipler and mosca it says that the number of significant figures in the result of addition or subtraction is no greater than the least number of significant figures beyond the decimal place of any of the numbers.
They give the example of 1.040+0.21342. Clearly, 1.040 has three significant figures beyond the decimal place whereas 0.21342 has five. So the result can only have a maximum of three significant figures beyond the decimal place. Hence 1.040+0.21342=1.253.
I have two questions:
1. Is "number of significant figures after the decimal point" simply another way of saying "decimal places"? (So would it be correct in the above example to say "1.253 (3 d.p)"?)
2. When we try to apply the rule to [tex]2.34\cdot 10^2+4.93[/tex], is the answer 238.93 or 2.39*10^2, and why?
If you express
walking said:
2. When we try to apply the rule to ##2.34\cdot 10^2+4.93##, is the answer 238.93 or 2.39*10^2, and why?
What rule are you applying? Note that the number of significant figures implied by the addition is 3 (what's to the left of the decimal counts) so 238.93 has 5 sig figs and is incorrect while 2.39×102 has 3 sig figs and is correct. For more on this go to
https://en.wikipedia.org/wiki/Significant_figures
kuruman said:
If you express
I am applying the rule I mentioned at the start of my post. Tipler and Mosca say that there are two separate rules, one for multiplication and division of numbers, the other for addition and subtraction. The rule you are telling me is the one they say should be applied to multiplication and division, not addition and subtraction. Thus, I think your answer is wrong.
If you want to make it a procedure using scientific notation, you could do this:
1. Convert one of the two numbers to share the same decimal exponent as the other. So either $$2.34\cdot 10^2 + 0.0493 \cdot 10^2$$ or $$234\cdot 10^0 + 4.93\cdot 10^0$$
2. Perform the addition.
3. Round off to remove any result digits where either addend has become insignificant. Either way, the "93" in the sum is insignificant and is rounded away.
This procedure agrees with what @kuruman is saying.
Note: If you are doing a multi-step calculation, you would not round off after each operation. Instead, you would keep track of the significant figures at each step along the way, noting which digits are significant or insignificant. You would keep full accuracy throughout the calculation and round only for the final reported result.
Related to Tipler/Mosca significant figures
1. What are significant figures and why are they important in Tipler/Mosca?
Significant figures refer to the digits in a number that are considered reliable and meaningful. In Tipler/Mosca, significant figures are important because they help to maintain the accuracy and precision of calculations and measurements.
2. How do you determine the number of significant figures in a given number?
In Tipler/Mosca, the general rule for determining the number of significant figures is to count all non-zero digits and any zeros between two non-zero digits. Trailing zeros after a decimal point are also considered significant. However, leading zeros and trailing zeros before a decimal point are not significant.
3. Can significant figures be used in addition and subtraction calculations?
Yes, significant figures can be used in addition and subtraction calculations. The result should have the same number of decimal places as the number with the fewest decimal places in the calculation.
4. How are significant figures handled in multiplication and division calculations?
In multiplication and division calculations, the result should have the same number of significant figures as the number with the fewest significant figures in the calculation.
5. Are there any exceptions to the rules of significant figures in Tipler/Mosca?
Yes, there are a few exceptions to the rules of significant figures in Tipler/Mosca. For example, when using logarithms or antilogarithms, the number of significant figures should be based on the number of decimal places in the input value. Also, when using exact numbers (such as conversion factors), the number of significant figures is not limited.
  • Other Physics Topics
