What Factors Cause a Water Container to Tip Over When Accelerated?
kbannister
A weightless cylindrical tank of diameter D and height H rests on a nonslip surface on a flatcar going around a circular track of radius R. The tank contains water to depth h with a free surface, and we assume h < H such that water won't slop over the tank's edge. The flatcar's speed is gradually increased to V. Two possibilities exist: 1. Only part of the water occupies the "ungula" (the heel-shaped volume under the sloping free surface, and 2. All the water ends up in the Ungula, exposing some of the tank's floor. At what value of V will the tank begin to tip over?
Radial acceleration, a = V^2/R;
Angle of free surface, alpha = arctan(a/g), where g = acceleration of gravity
Not clear how to proceed. Does the cylindrical surface of the ungula need to be considered?
Yes.
What attribute of the water volume do you need to determine in order to decide whether it will tip?
haruspex said:
Yes.
Assume the water has a weight density of gamma.
The question concerns determining the speed, V, around the circular track of radius R. A simpler version of the problem is the situation when the container is accelerated in a straight line at acceleration a.
No, that's an attribute of the water itself. I asked for an attribute of the volume (shape) the water occupies.
haruspex said:
Yes.
The tank is cylindrical, diameter D, height H, water depth h where h < H so that the water won’t spill over.
Will a diagram help? Does it need anything added?
For any object of given weight standing (not slipping) on a horizontal surface and subject to a sideways force of given magnitude, what determines whether it will tip over?
What (and how much of it) would make the container tip over in that simpler version?
FAQ: What Factors Cause a Water Container to Tip Over When Accelerated?
What role does the shape of the container play in tipping over when accelerated?
The shape of the container significantly influences its stability. Containers with a wide base and a low center of gravity are more stable and less likely to tip over. Conversely, tall and narrow containers have a higher center of gravity, making them more prone to tipping when subjected to acceleration.
How does the level of water in the container affect its stability during acceleration?
The water level within the container can affect its center of gravity. A container that is filled to the top has a higher center of gravity compared to one that is partially filled. A higher center of gravity increases the likelihood of the container tipping over when accelerated.
What impact does the acceleration direction have on the likelihood of the container tipping over?
The direction of acceleration relative to the orientation of the container plays a crucial role. Lateral (sideways) acceleration is more likely to cause tipping compared to longitudinal (forward or backward) acceleration. This is because lateral forces can more easily overcome the base's support compared to forces aligned with the container's length.
How does the surface friction between the container and the surface it rests on affect tipping?
Surface friction is a key factor in preventing tipping. A higher friction coefficient between the container and the surface it rests on provides more resistance against sliding and tipping. Conversely, a slippery surface reduces friction, making the container more susceptible to tipping when accelerated.
Does the distribution of water inside the container influence its stability during acceleration?
Yes, the distribution of water inside the container can significantly affect its stability. If the water is unevenly distributed, the center of gravity shifts towards the heavier side, increasing the likelihood of tipping. Even distribution of water helps maintain a lower and more central center of gravity, enhancing stability.
