Tipping of a cabinet and determining velocity at a given point?
  • Thread starter Thread starter StephenHaw
    Point Velocity
The discussion focuses on calculating the tipping point of a cabinet when a force is applied to its upper edge. It establishes that a cabinet weighing 60kg requires a force of approximately 147.15 N to begin tipping, with the angle of the center of gravity to the pivot edge calculated at 26.56 degrees. The conversation explores how to determine the kinetic energy of the cabinet once a force of 200 N is applied and then removed after tipping 10 degrees. It emphasizes the need to consider the gravitational potential energy and the work done by the external force to understand the cabinet's motion post-application of force. The participants are seeking a method to apply these principles to different cabinet configurations.
StephenHaw
TL;DR Summary
A question on tipping, a cabinet is subject to a force greater than the tipping force to an angle of 10 degrees when the applied force is removed, how do I determine if momentum will cause the cabinet to fall over or fall back?
I am trying to determine if there is a set of formula to calculate if a cabinet will when subjected to a force on it's upper edge for an angular distance (not a duration) will gain enough momentum to continue over the balance point and fall over or whether the opposing moment due to mass and gravity will counter the momentum and return the cabinet to it's base.
I already know that for a turning moment that if F1D1 = F2D2 at the point at which tipping will begin: So a cabinet that is 1m tall, 0.5m wide and weight 60kg on a non slip floor would need just over 60*9.81*0.25/1 = 147.15 N to begin to move when the load is applied at the top edge of the cabinet.
The angle at which the CofG is to the pivot edge from the vertical plane is from trig tan-1 (0.25/0.5) = 26.56 degrees
However if a test required a 200N applied force on the cabinet we would know the difference in the applied turning moment would be 52.85N
causing the cabinet to tip. The force of 200N is constant and applied until the cabinet has tipped 10 degrees at which point the applied force is removed.
Now what I am trying to work out is how much K.E. is obtained by the cabinet at the point where the force is removed to understand its velocity to then work out how much further the cabinet will travel before either falling back onto its base or carrying on beyond the pivot point
and fall over.
In this respect perhaps I might be over thinking the problem, as I consider the turning moment applied by gravity is reducing as it approaches the balance point so the value for acceleration increases due to the increasing difference in the applied force and its opposing turning moment due to gravity.
The method to solve this I could then apply to different cabinets of different heights, widths and mass.
Any advice will be greatly appreciated.
The work done by a force is the inner product of the force and displacement. The work done by gravity on a body is directly related to the vertical displacement of its centre of mass.
If I imagine your scenario correctly, you could calculate the increased gravitational PE at the tipping point, and assuming minimal KE at that point, calculate the work needed by an external force to topple the object.
Thanks for the reply and it gives me a new perspective on the problem in terms of work and energy to see if there is a methodology there that I can apply.
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved. He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been...
TL;DR Summary: Heard in the news about using sonar to locate the sub Hello : After the sinking of the ship near the Greek shores , carrying of alot of people , there was another accident that include 5 tourists and a submarine visiting the titanic , which went missing Some technical notes captured my attention, that there us few sonar devices are hearing sounds repeated every 30 seconds , but they are not able to locate the source Is it possible that the sound waves are reflecting from...
