Titan's atmosphere vs temperature.
In summary, Titan's thick atmosphere plays a crucial role in regulating its temperature, creating a greenhouse effect that keeps its surface warm. The average temperature on the moon is approximately -179 degrees Celsius, due to its distance from the Sun and the composition of its atmosphere. Compared to Earth, Titan's atmosphere is denser and richer in nitrogen and methane. Temperature differences on the moon are caused by its axial tilt and changing distance from the Sun, resulting in seasonal changes and variations in solar radiation. While the extreme cold temperatures make it unlikely for life to exist on the surface, there is a possibility of microbial life in Titan's liquid methane lakes or subsurface ocean.
tanzanos
62
I was wondering at what temperature would Titan's atmospheric particles reach escape velocity? Since Titan lacks the mass to hold onto its present atmosphere then would I be wrong to conclude that what holds such a thick atmosphere is the extremely low temperatures found on Titan?
Astronomy news on Phys.org
The escape velocity is 2.6km/s, at ~100K a typical energy for nitrogen is ~240m/s, a factor of 10 below the escape velocity. In terms of energy, this is a factor of 100, that's fine.
The temperature would have to be significantly higher to get large losses.
Likes 1 person
Related to Titan's atmosphere vs temperature.
1. How does Titan's atmosphere affect its temperature?
The thick atmosphere of Titan plays a major role in regulating the planet's temperature. It traps heat from the Sun, creating a greenhouse effect that keeps the surface of the moon warm.
2. What is the average temperature on Titan?
The average temperature on Titan is approximately -179 degrees Celsius (-290 degrees Fahrenheit). This is due to its distance from the Sun and the composition of its atmosphere.
3. How does Titan's atmosphere compare to Earth's?
Titan's atmosphere is much denser and thicker than Earth's, with a surface pressure about 50% higher. It is also composed mostly of nitrogen, like Earth's atmosphere, but also contains significant amounts of methane and other hydrocarbons.
4. What causes the temperature differences on Titan?
The temperature differences on Titan are mainly caused by its axial tilt and its changing distance from the Sun as it orbits Saturn. This results in seasonal changes and variations in solar radiation received by the moon.
5. Can the temperature on Titan support life?
The extreme cold temperatures on Titan make it unlikely for life as we know it to exist on the surface. However, there is a possibility of microbial life existing in the liquid methane lakes on Titan's surface or in the subsurface ocean of liquid water under its icy crust.
10K
11K
