Titration lab with potassium permanganate
In summary, the conversation is discussing the use of ammonium iron(II) sulphate hexahydrate as a primary standard in an experiment. The first part of the conversation involves calculating the number of millimoles of ammonium iron(II) sulphate hexahydrate in a 1.0000g sample. The second part involves finding the balanced equation for the oxidation of iron(II) ion by permanganate and determining the number of millimoles of permanganate ion that react with one millimole of ammonium iron(II) sulphate. The final part of the conversation involves calculating the number of millimoles of permanganate ion needed to titrate 1.0000g
cottonz
1.The primary standard in thiss experiment is ammonium iron(II) sulphate hexahydrate, (NH4)2Fe(SO4)2*6H2O. Calculate the number of millimoles of ammonium iron(II) sulphate hexahydrate in a 1.0000g sample.
2.Give the balanced equation for oxidation of iron(II) ion by permanganate and find how many millimoles of permanganate ion react with one millimole of ammonium iron(II) sulphate.
3.Calculate the number of millimoles of permanganate ion that titrates 1.0000g of ammonium iron(II) sulphate.
The balanced equation for 2 is MnO4^- + 8H^+ + 5Fe^2+ ---> Mn^2+ + 4H20 + 5Fe^3+
For #1, would I just use 1.0000g x (1mol/molar mass of ammonium iron(II) sulphate hexahydrate) then change the answer into millimoles. I get 2.5501millimoles
For #2, would I use the moles/millimoles I got for #1 and use the ratio from the equation? But where does the ratio come from if ammonium iron(II) sulphate isn't in the balanced equation?
You know how to calculate number of moles of Fe2+ per mole of Mohr's salt, but you don't know how to calculate number of moles of Mohr's salt that contain a mole of Fe2+? It is the same thing, just the ratio is reversed (which doesn't matter here, as 1/1=1).
FAQ: Titration lab with potassium permanganate
What is the purpose of a titration lab with potassium permanganate?
The purpose of a titration lab with potassium permanganate is to determine the concentration of a substance in a solution. Potassium permanganate is a strong oxidizing agent that reacts with certain substances, allowing for the calculation of their concentration.
What materials are needed for a titration lab with potassium permanganate?
The materials needed for a titration lab with potassium permanganate include: a burette, a conical flask, potassium permanganate solution, a pipette, a white tile, a standard solution of a known concentration, and a solution of the substance being tested.
How is a titration lab with potassium permanganate performed?
A titration lab with potassium permanganate is performed by adding a measured volume of the potassium permanganate solution to a conical flask containing a measured volume of the substance being tested. The color of the solution will change as the reaction occurs. The volume of the potassium permanganate solution needed to completely react with the substance can then be used to calculate the concentration of the substance.
What is the endpoint in a titration lab with potassium permanganate?
The endpoint in a titration lab with potassium permanganate is the point at which the color of the solution changes permanently, indicating that the reaction is complete. This is typically indicated by a color change from purple to colorless.
What are the sources of error in a titration lab with potassium permanganate?
Sources of error in a titration lab with potassium permanganate can include inaccurate measurement of volumes, incomplete reaction, and human error in determining the endpoint. It is important to carefully follow the procedure and perform multiple trials to minimize these sources of error.
