Chris L
- 14
Determine the pH at the equivalence point after 20.00mL of a 3.75 M NaF(aq) solution is titrated with 3.25 M HI(aq)
##k_a = \frac{[A^-][H^+]}{[HA]}##
The first thing I noted was that
NaF ##\rightarrow## Na+(aq) + F-(aq)
since most sodium compounds dissolve almost completely, and
HI ##\rightarrow## H+(aq) + I-(aq)
since hydroiodic acid is strong. From there, the equilibrium expression
HF ##\rightleftharpoons## H+(aq) + F-(aq)
came to mind. Since the volume of HI(aq) added is one molar equivalent, and there are
## 0.02 L (3.75 \frac{mol}{L}) = 0.075 mol## of NaF(aq) in solution, I figured the volume of HI(aq) added must be ##\frac{0.075 mol}{3.25 \frac{mol}{L}} = 0.0231 L##. The total volume is then ##0.02 L + 0.0231 L = 0.0431 L##.
From the total volume, I found the new H+(aq) and F-(aq) concentrations to be ##\frac{0.075 mol}{0.0431 L} = 1.74 M##; from my understanding, the initial concentrations of both of these entities should be the same because exactly 1 molar equivalence is being added and they are in a 1:1 ratio with each other.
Next, I created an ICE table with this information, along with the provided ##k_a## = 6.6 x 10-4 (I'm new to LaTeX so I put it inside a matrix b/c there's documentation for them in the FAQ, apologies):
\begin{pmatrix}
? & HF & H^+ & F^-\\
I & 0 & 1.74 & 1.74\\
C & +x & -x & -x\\
E & x & 1.74 - x & 1.74 - x
\end{pmatrix}
Plugging this information into the expression for ##k_a##,
##6.6*10^{-4} = \frac{(1.74 - x)^2}{x}##
which yields ##x = 1.7064## and so ##[H^+] = 1.74 - 1.7064 = 0.0336 M##.
Finally, ##pH = -log_{10}(0.0336) = 3.39##, which seems like a somewhat reasonable answer given the strength of the acid being added, but I still feel like there are errors in my methodology. I would be very thankful if anyone could point out my mistakes, or just tell me if everything looks okay!
