Tj's question at Yahoo Answers regarding finding the area between two functions
In summary: So, in summary, the area between the curves y= x^2 -8, y= -2x, and x=4 is given by the integral setup A= Integral:(-4 to 2) (-2x- x^2 +8)dx + Integral:(2 to 4) (x^2 -8 + 2x) dx, which is derived by finding the intersection points between the two functions and setting up the integral as the greater function minus the lesser function, resulting in a non-negative integrand. We then solve the integral and find the area to be 152/3.
MarkFL
MHB
13,288
Here is the question:
Find the area between the curves?
Find the area between the curves y= x^2 -8, y= -2x, and x=4
The teacher says the integral setup is
Area= Integral:(-4 to 2) (-2x- x^2 +8)dx + Integral:(2 to 4) (x^2 -8 + 2x) dx
How did the teacher get that?
I have posted a link there to this topic so the OP can see my work.
Mathematics news on Phys.org
Re: Tj's question at Yahoo! Anwwers regarding finding the area between two functions
Hello Tj,
The area between two curves is given by:
\(\displaystyle A=\int_a^b\left|f(x)-g(x) \right|\,dx\)
In order to get rid of the absolute value, we need to make sure we have a non-negative integrand, that is we have the greater function minus the lesser function. Let's take a look at the area in question for this problem:
We see that the linear function is greater than the quadratic in between their points of intersection, and then the quadratic is the greater function to the right of the points of intersection, but to the left of the bounding line $x=4$.
So, we need to determine the $x$-coordinates of the intersection points, so we may equate the two function and solve for $x$:
\(\displaystyle x^2-8=-2x\)
\(\displaystyle x^2+2x-8=0\)
\(\displaystyle (x+4)(x-2)=0\)
Hence, we find \(\displaystyle x=-4,2\).
So, we find that given area with:
\(\displaystyle A=\int_{-4}^2(-2x)-\left(x^2-8 \right)\,dx+\int_2^4 \left(x^2-8 \right)-(-2x)\,dx\)
Simplify:
\(\displaystyle A=\int_{-4}^2 8-2x-x^2\,dx+\int_2^4 x^2+2x-8\,dx\)
This is equivalent to what your teacher gave. Let's go ahead and find the area:
\(\displaystyle A=\left[8x-x^2-\frac{1}{3}x^3 \right]_{-4}^2+\left[\frac{1}{3}x^3+x^2-8x \right]_2^4=\)
\(\displaystyle \left(8(2)-(2)^2-\frac{1}{3}(2)^3 \right)-\left(8(-4)-(-4)^2-\frac{1}{3}(-4)^3 \right)+\left(\frac{1}{3}(4)^3+(4)^2-8(4) \right)-\left(\frac{1}{3}(2)^3+(2)^2-8(2) \right)=\)
\(\displaystyle \frac{28}{3}+\frac{80}{3}+\frac{16}{3}+\frac{28}{3}=\frac{152}{3}\)
FAQ: Tj's question at Yahoo Answers regarding finding the area between two functions
What is the purpose of finding the area between two functions?
Finding the area between two functions is important in mathematics and physics. It allows us to calculate the total amount of space or volume enclosed by the two functions, which can be useful in various real-life scenarios such as calculating the area under a curve for a given set of data.
How do I find the area between two functions?
To find the area between two functions, you need to first graph the two functions on the same coordinate plane. Then, you can use basic integration techniques to find the definite integral of the difference between the two functions over a given interval. This will give you the area between the two functions.
What is the difference between finding the area between two functions and finding the area under a curve?
The area between two functions is the space enclosed by the two functions on a given interval, while the area under a curve is the space enclosed by a single function on a given interval. The process of finding the area between two functions involves subtracting one function from the other, while finding the area under a curve involves integrating a single function over a given interval.
Can I use any integration method to find the area between two functions?
Yes, you can use any integration method that is appropriate for the given functions. This could include the basic integration rules, substitution, or integration by parts. It is important to choose the most efficient method for the given functions to avoid complex calculations.
Are there any real-life applications of finding the area between two functions?
Yes, there are many real-life applications of finding the area between two functions. For example, in physics, this can be used to calculate the work done by a variable force on an object. In economics, it can be used to calculate the total revenue or profit for a given business model. In general, it can be used in any scenario where finding the total enclosed space or volume is necessary.
