To converge or to diverge, thats the q
  • Thread starter mynameisfunk
In summary, the conversation discusses the use of the comparison test and a theorem involving monotone sequences to prove or find counterexamples for two statements involving convergent series: (i) If \sum a_n converges, then \sum \frac{a_n}{\sqrt{n}} converges; and (ii) If \sum a_n converges, then \sum \frac{|a_n|}{n} converges. The conversation also includes a suggestion to use the constructed series \sum 2^k a_{2^k} for proving convergence of monotone decreasing sequences.
mynameisfunk
125
Prove or find a counterexample:
(i) If [itex]\sum a_n[/itex] converges, then [itex]\sum \frac{a_n}{\sqrt{n}}[/itex] converges.
(ii) If [itex]\sum a_n[/itex] converges, then [itex]\sum \frac{|a_n|}{n}[/itex] converges.
for (i) I really haven't much of a clue.
for (ii) I am also confused but my thinking was that I could take a series [itex]\sum a_n[/itex] that is not absolutely convergent and then since two divergent series are multplied together then they must diverge. However, I know that if I take [itex]a_n=\frac{(-1)^n}{n}[/itex]that this won't work out since [itex]\sum \frac{1}{n^2}[/itex] converges...
I would really like some help on this, and if you could i would like to be briefed on what a good strategy is for thinking about these problems, it seems like the amount of tests and manipulations that are possible are very overwhelming.
This may be overkill, but... theorem:
If [tex] \sum a_n [/tex] converges and if [tex] b_1, b_2, ... [/tex] is a bounded monotonic sequence of numbers, then [tex] \sum a_n b_n [/tex] converges.
or the comparison test
Number one, using comparison test to prove that the sequence converges.
Number two, construct a monotone decreasing sequence out of the given sequence such that the new sequence is less or equal to the given sequence, then use the theorem below, to show that the constructed series diverges, thus the given sequence diverges
(this is my first post, and i don't know why my latex isn't working right, sorry. )
OK this is a test,
ill try to rewrite the theorem in latex
For any given monotone decreasing sequence {a_n}, the series [tex] \sum a_n [/tex] converges
if and only if
[tex] \sum 2^k a_{2^k}, k=0,1,2,3,... [/tex] converges.
[tex]\sum 2^k a_{2^k} = a_1+2a_2+4a_4+8a_8+...[/tex]
Remark: this theorem works great when you have n (the index) in the denominator, because it cancels out with the 2^k in the front!
for example: the series [tex] \sum \frac{b_n}{n} [/tex] converges if and only if
[tex] \sum 2^k \frac{b_{2^k}}{2^k} = 1\frac{b_1}{1}+2\frac{b_2}{2}+4\frac{b_4}{4}...= b_1+b_2+b_4+b_8+...[/tex] converges.
you can try to prove [tex]\sum 1/n[/tex] diverges using this theorem as a practice to get familiar with it.
FAQ: To converge or to diverge, thats the q
What does it mean for a series to converge or diverge?
A series is said to converge if its terms approach a specific finite value as the number of terms increases. On the other hand, a series is said to diverge if its terms do not approach a finite value and instead continue to increase or decrease without bound.
How can I determine if a series converges or diverges?
There are several tests that can be used to determine if a series converges or diverges, such as the ratio test, the root test, and the integral test. These tests involve analyzing the behavior of the terms in the series and comparing them to a known convergent or divergent series.
What is the significance of convergence and divergence in mathematics?
Convergence and divergence play a crucial role in mathematics, particularly in calculus and analysis. They allow us to determine the behavior and properties of infinite series, which have many real-world applications in fields such as physics, engineering, and finance.
Can a series both converge and diverge?
No, a series can only either converge or diverge. If a series converges, it cannot also diverge, and vice versa. However, a series can approach a finite limit and still be considered divergent, known as conditionally convergent.
What is the difference between absolute convergence and conditional convergence?
Absolute convergence occurs when a series converges without any conditions on the signs of its terms. On the other hand, conditional convergence occurs when a series converges only if certain conditions on the signs of its terms are met. In other words, conditional convergence is a subset of absolute convergence.
