To find out the forces in a link mechanism
In summary, the conversation discusses a homework problem involving a link mechanism in static equilibrium. The goal is to calculate the forces F and Q acting on link 2, given its length and a moment applied to it. The solution involves resolving the force at a pivot point and taking the summation of moments at point B to find the resultant force. However, the distance required for this calculation depends on the unknown angle θ2, which the person is struggling to find. They ask for help in finding the angle by identifying a point K and taking moments about it.
chiraganand
113
The figure attached contains the link mechanicsm in static equilibrium. The forces F for the link 2 and Q has to be calculated. Given the length of link 2 is 4 cm and a moment of 50 Nm is applied to link 2
The attempt of solution is that at the pivot point 1 the force is resolved into two components the horizontal component and vertical component. We have a moment given to the link 2. Hence taking the summation of moments about the point B as zero we can find the horizontal and vertical components of the force and hence the resultant force acting on the link. to find the moment of the horizontal component and vertical components of the force we require the distance from the point B. I am unable to find this distance as it depends on the angle θ2 .
Hence i want to find the angle θ2 and i am unable to find it.
Please help me in finding the angle and please let me know if the my above approach is correct
Please someone help me out in this!
You could try this: Identify a point K which is the intersection of the lines of action of members 2 and 4. This is actually the instantaneous centre of rotation of the triangle BCD with the 30 and 40 degree angles. Now, what happens when you take moments about K?
FAQ: To find out the forces in a link mechanism
What is a link mechanism?
A link mechanism is a mechanical system made up of connected links or bars that can transfer motion or force from one point to another. It is commonly used in machines and mechanical devices to create specific movements or functions.
How do you determine the forces in a link mechanism?
The forces in a link mechanism can be determined by using the principles of statics and mechanics. This involves analyzing the geometry and constraints of the mechanism, as well as the external forces acting on it, to calculate the internal forces within the links.
What factors affect the forces in a link mechanism?
The forces in a link mechanism are influenced by several factors, including the geometry and size of the links, the type of connections between the links, and the external forces acting on the mechanism. Friction and wear can also affect the forces in a link mechanism over time.
Can computer simulations be used to find the forces in a link mechanism?
Yes, computer simulations can be used to analyze link mechanisms and determine the forces within them. These simulations rely on mathematical models and equations to simulate the behavior of the mechanism and calculate the forces at different points.
How are the forces in a link mechanism useful?
Understanding the forces in a link mechanism is crucial for designing and optimizing mechanical systems. It allows engineers to ensure that the mechanism can handle the expected loads and stresses, and make any necessary adjustments to improve its performance and longevity.
