To find speed of a plane when position of radar is given
In summary, the plane is flying at a constant velocity but the angle it makes from the radar tower changes constantly.
hermy
41
A plane flying at a constant velocity v (parallel to x-axis) at a height h = 8 km is being tracked by a radar located at origin. if the angle A is decreasing at the rate of 0.025 rad/s, the velocity of the plane when A = 60 degrees is: (A is the angle made by the position vector of plane with the x-axis)
a) 1440 km/h
b) 960 km/h
c) 1920 km/h
d) 480 m/h
vt = h cot A
differentiating w.r.t t (time):
v = h cosec2 A (0.025) -------eqn 1
= 0.27 km/h
the answer is nowhere near what one would expect. also, if v is consatant then how can it depend on A? (eqn 1) Where am i going wrong?
Is this question so tough, or is it unclear?
Any help would be appreciated, pls..
I was actually really stumped on this question. The maths was telling me there's no solution...
It's because there is a contradiction in the information. The plane can't be flying at constant velocity AND the angle it makes from the radar tower changes constantly too. The question needs fixing up.
Perhaps it doesn't state angle changes with a constant speed, but it changes with a given speed when angle is 60 deg?
Oh yes you're right Borek, the question implies the angle is changing at that rate at the given angle, not constantly (of course)...
Well then the only problem is that your units are incorrect.
It's actually 4/15 km/second, not km/hour.
To realize what units you need for future questions without going through the entire problem using units constantly, just notice that the height is in km, and that the angle was changing at some value in seconds. km/sec.
that's right, mentallic. so, the answer would be 960 km/h. the answer was supposed to be (b), so that must have been the only mistake in the question. a pretty silly doubt actually, so thanks a lot for taking the trouble to set it right.
and yes, the rate of change of angle must be instantaneous, that seems to be the only way v can be constant.
thanks everyone!
hermy said:
so, the answer would be 960 km/s.
960 km/h to be exact :-p
Related to To find speed of a plane when position of radar is given
1. How does the radar system calculate the speed of a plane?
The radar system calculates the speed of a plane by using the principle of Doppler shift. It measures the change in frequency of the radar signal as it bounces off the plane, and uses this information to determine the speed of the plane relative to the radar station.
2. Is the speed of the plane different from the speed shown on the radar?
Yes, the speed shown on the radar is the ground speed of the plane, which is the speed of the plane relative to the ground. The actual speed of the plane, known as airspeed, may be different due to factors such as wind and air density.
3. Can the radar system accurately measure the speed of multiple planes at the same time?
Yes, modern radar systems are equipped with advanced technology that allows them to track and measure the speed of multiple planes simultaneously.
4. What happens if the radar station is moving while tracking a plane?
If the radar station is moving, the speed of the plane will be affected by the relative motion between the radar station and the plane. In this case, the radar system will use additional information, such as the heading and altitude of the plane, to calculate the true speed of the plane.
5. Are there any limitations to using radar to determine the speed of a plane?
Yes, there are certain limitations to using radar to determine the speed of a plane. These include factors such as weather conditions, radar range, and the size and shape of the plane. Additionally, the accuracy of the speed measurement may be affected by technical issues or human error.
