To measure a Planck length would require a black-hole photon?
In summary, the conversation discusses the idea that a photon with enough energy to discern a Planck length would be equivalent to a black hole. However, this argument is not valid as a photon cannot be localized in space. Additionally, at the energy level required, the concept of a photon is no longer valid. The recommended source for learning physics is textbooks and peer-reviewed papers, rather than pop science videos.
swampwiz
571
83
I was viewing this video in which the narrator says that the energy of a photon that could discern a Planck length would require a photon of such high energy that it would be a de factor black hole. Is this accurate?
The video itself looks quite reasonable, but that particular statement is fairly meaningless. An energetic photon isn't a black hole.
Likes vanhees71
Maybe it's a Kugelblitz instead ?
It's not that either. It's just a very energetic photon you need.
The idea seems to be that the photon would have an energy so high, and concentrated into a space so small, that there would be enough equivalent mass to create a microscopic black hole.
A photon isn't "concentrated into space"; it can't be localized the way a particle with nonzero rest mass can be. So this argument, although it sounds plausible (since it is mathematically true that a black hole with Schwarzschild radius equal to the Planck length does have energy equal to the Planck energy, which is, heuristically, the energy a photon would have to have to allow it to pin down the position of an object to within a Planck length), is not valid.
Likes vanhees71
I understand the idea - it's simply mistaken. A photon is not localised, hence cannot be a black hole.
Likes vanhees71
It is worth noting, in addition to the other objections that have already been made, that this energy (the Planck energy) is way, way above the electroweak symmetry breaking energy, so "photon" is no longer a valid concept anyway; at this energy, the appropriate quantum fields would be the "bare" electroweak fields (##W_1##, ##W_2##, ##W_3##, and ##B##), all of which are massless at this energy. So even the general idea of localizing anything to within a Planck length is probably not valid.
Likes vanhees71 and PeroK
Here's another video discussing this. He talks about the black hole at around 15:00.
  • Sad
Likes Dale
Still the same basic argument, and the same issues that have already been raised.
The proper source from which to learn physics is textbooks and peer-reviewed papers, not pop science videos.
Likes vanhees71
The OP question has been answered. Thread closed.
FAQ: To measure a Planck length would require a black-hole photon?
1. What is a Planck length?
The Planck length is a unit of length in the field of quantum mechanics, named after the physicist Max Planck. It is the smallest meaningful length that can be measured in the universe and is approximately 1.6 x 10^-35 meters.
2. Why is measuring a Planck length difficult?
Measuring a Planck length is difficult because it is significantly smaller than any length that can currently be measured by scientific instruments. It is also beyond the resolution of our current understanding of physics.
3. What is a black-hole photon?
A black-hole photon is a photon (a particle of light) that is emitted from a black hole. It is called a black-hole photon because it is emitted from the event horizon of the black hole, which is the point of no return for anything that enters it.
4. How does a black-hole photon relate to measuring a Planck length?
To measure a Planck length, one would need to observe a black-hole photon as it travels through space. This is because the wavelength of a black-hole photon is thought to be equal to the Planck length, making it a potential way to indirectly measure this extremely small length.
5. Is it possible to measure a Planck length using a black-hole photon?
Currently, it is not possible to directly measure a Planck length using a black-hole photon. This is because our technology and understanding of physics are not advanced enough to accurately measure such a small length. However, scientists are continually researching and developing new methods for measuring extremely small distances.
