To measure the diameter of a sphere using a screw gauge
In summary, according to the given information, the screw gauge would give a reading of either 2 mm or 3.14 mm. The correct answer is given as 2.64 mm, option A.
Amitkumarr
A screw gauge has pitch 1.5 mm and there is no zero error. Linear scale has marking at MSD = 1 mm and there are 100 equal division of circular scale. When diameter of a sphere is measured with instrument, main scale is having 2 mm mark visible on linear scale, but 3 mm mark is not visible, 76th division of circular scale is in line with linear scale. What is the diameter of sphere?
Diameter=M.S.R + L.C×C.S.R
(there is no zero error)
Where M.S.R=Main scale reading
L.C=Least count of screw gauge
C.S.R=Circular scale reading
Least count of screw gauge= Pitch÷No. of divisions on circular scale
Least count of the screw gauge = Pitch÷No. of divisions on circular scale=1.5÷100 mm =0.015mm
According to me,in this case the main scale reading should be taken as 2 mm because it is the one which is visible and circular scale reading should be 76.
So, Diameter=2 mm + 0.015×76 mm
= 2 mm + 1.14 mm= 3.14 mm
But none of the given options matches my answer and the correct answer is given as 2.64 mm which is option A(in the attached question).
According to the solution manual, the Main scale reading should be 1× pitch=1.5 mm and the diameter should be 1.5 mm + (1.5÷100)×76 mm = 2.64 mm ,but why?
Where am I going wrong?
Suppose you start with the gauge reading zero; i.e., both the main scale and the circular scale read zero. After one full rotation of the screw, where will you be on the main scale?
Suppose the scale is measuring a distance of exactly 2 mm. Would the circular scale read zero?
When we start with the gauge reading zero,after one full rotation,we should be at a distance equal to 1.5 mm(equal to pitch) on the main scale.If the scale is measuring a distance of exactly 2mm,the circular scale would not read zero.
But,how we have to use the information that the 2mm mark is visible but the 3mm mark is not visible, in getting the main scale reading?
Right. The circular scale does not read zero when the main scale is exactly 2 mm.
But, your solution appears to assume that the circular scale does read zero when the main scale is exactly 2 mm. You wrote: Diameter=2 mm + 0.015×76 mm. So, you assumed that the additional amount beyond 2 mm equals the distance associated with 76 tick marks on the circular dial.
But, how we have to use the information that the 2mm mark is visible but the 3mm mark is not visible, in getting the main scale reading?
This tells you that the diameter of the sphere lies between 2 mm and 3 mm.
Likes Amitkumarr
Thanks a lot.I can now understand.
Related to To measure the diameter of a sphere using a screw gauge
1. How do you use a screw gauge to measure the diameter of a sphere?
To measure the diameter of a sphere using a screw gauge, first place the sphere between the jaws of the screw gauge. Then, turn the thimble until the jaws are gently touching the sphere. Take note of the measurement on the thimble and the main scale, and add them together to get the diameter of the sphere.
2. What is the accuracy of using a screw gauge to measure the diameter of a sphere?
The accuracy of using a screw gauge to measure the diameter of a sphere depends on the precision of the screw gauge. Most screw gauges have a precision of 0.01 mm, which means the measurement can be accurate up to 0.01 mm.
3. Can a screw gauge be used to measure the diameter of any size of sphere?
Yes, a screw gauge can be used to measure the diameter of any size of sphere as long as the sphere can fit between the jaws of the screw gauge. However, for larger spheres, it is recommended to use a larger screw gauge with a wider range of measurements.
4. What is the difference between a screw gauge and a caliper for measuring the diameter of a sphere?
A screw gauge is a more precise tool for measuring the diameter of a sphere as it has a smaller scale and can measure up to 0.01 mm accuracy. A caliper, on the other hand, has a larger scale and can measure up to 0.1 mm accuracy.
5. How many times should I measure the diameter of a sphere using a screw gauge to ensure accuracy?
To ensure accuracy, it is recommended to measure the diameter of a sphere at least three times using a screw gauge and take the average of the measurements. This helps to account for any slight variations in measurements and provides a more accurate result.
87K
32K
